What are the dimensions...
Old Feb 18, 2004 | 11:01 PM
Cruz's Avatar
of the 7 spoke premium wheels. I know they're 18's but what's the width & offset (if any). I want to get new wheels but I'm gonna stick w/ 18's & I'd like to use the tires that I already have.
Thanx
XMLM
Old Feb 19, 2004 | 11:06 AM
ryoken's Avatar
Re: What are the dimensions...
Check your owner's manual.
Chapter 10, Technical and Consumer Information
Page 10-8, Wheels and Tires
Here's a copy of the page:
Old Feb 19, 2004 | 04:19 PM
Cruz's Avatar
Thanx, you saved me from a paper cut.
XMLM
Old Feb 19, 2004 | 04:25 PM
ryoken's Avatar
Download the manual in PDF format. [img]/w3timages/icons/smile.gif[/img]
You don't think I scanned the page in that clearly, do you? [img]/w3timages/icons/tongue.gif[/img]
Old Feb 19, 2004 | 06:42 PM
jsunandmax's Avatar
so, to be clear, if i have the 18" premium wheels on my new coup, they are the same in front and back? same width etc?
i can replace them with any 18" wheel that has the same bolt-on pattern, right ?
or do i need the 8JJ width to use my current tires....?
Old Feb 19, 2004 | 07:10 PM
Cruz's Avatar
Looks to be that way...I'm going w/ 18 x 8.5 in the front & 18 x 9.5 in the rear. The place where I'm getting my wheels from says that I can still mount the stock Pilots on the new wheels w/ no problems.
XMLM
Old Feb 20, 2004 | 01:42 AM
ryoken's Avatar
If you want to keep the same size wheels, it's 18x8 (ignore the JJ.. don't really know what that means) with a 30mm offset. The bolt pattern absolutely has to be the same (5x114.3).. everything else is negotiable, suspension/fenders/brakes permitting.
Old Feb 24, 2004 | 12:09 AM
Cruz's Avatar
So what the guy told me is wrong? The stock Pilots will not fit the 18x8.5 / 18x9.5 wheels?
XMLM
racefan318
Dec 29, 2008 10:47 PM
