Getting a deal on a set of PS2's
Im getting a hell of a deal on Michelin PS2's.... but they only have 265/35/19 and 245/35/19 , will these be okay on my OEM 19's? I looked at the tire size calculator, and they seem to be okay.... What do you guys say?
245/35/19 on stock 19s is okay.
i believe 265/35/19 on the stock 19s is slightly out of the manufacturer's recommendations, but would probably be okay. 255/40 is probably the widest you should go in the rear.
Originally Posted by chilibowl
okay ima pick these up tomorrow then, the threading on the inside of my front shi.tenzas is starting to come out
Negative camber FTMFL
Negative camber FTMFLJoined: Apr 2005
Originally Posted by aHero4Eternity
How much camber are you running up front?
