wheels spacers???
Old Nov 10, 2007 | 02:46 PM
TwilightBLUES's Avatar
wheels spacers???
i want to get wheel spacers for the rear. i have 275/30/19's on the back with tien basic coilovers. what are my possible sizes? to be honest im not too familiar with spacers. thanks for the help!
Old Nov 10, 2007 | 03:44 PM
SteveBlake's Avatar
do you have stock rims? depending on your current offsets is how big of a spacer you can put on.
Old Nov 11, 2007 | 07:20 AM
no they are not stock, 275/30/19 i want the rear to stick out a bit more, i dont know how the sizes go.
who here has some experience with spacers???
Old Nov 11, 2007 | 01:25 PM
fbw5595's Avatar
We need the offset of your wheels for someone to help, I believe.
Old Nov 12, 2007 | 04:49 AM
isnt 275/30/19 the offset? or do u mean 19x10
Old Nov 12, 2007 | 04:59 AM
BayAreaRefuGz's Avatar
i fly low
what year is your car and what size rims do you have it sitting on? 17s/18s/19s?
we could help you with that kind of info.
-jeff
Old Nov 12, 2007 | 05:01 AM
i fly low
OEM 19s doesnt come in 19x10. correct me if i'm wrong, the stock setup is 19x8(F) 19x9(R)
Old Nov 12, 2007 | 01:31 PM
ok well lets see its an 04 coupe brembos the rims are not STOCK. which is why i said 19x10, the rims are ROJA Sevens, the tires are 275/30/19
Old Nov 12, 2007 | 01:33 PM
Calvin's Avatar
Overglorified Altima
You still haven't told us the offset. 19 would be the diameter, 10 would be the width.
Definition of offset:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Without the offsets, we can't help you.
example of offsets: +17, +20, +25, +27, etc.
^^that is what people are referring to when they ask for offsets.
Old Nov 13, 2007 | 03:12 AM
i c thank you hero!!! now my only prob is finding out what offset i have, hmmm thats gona be tricky, i feel dumb
Old Nov 14, 2007 | 01:07 AM
nokimchi2's Avatar
what size of spacer is recommended for stock 18"
Old Nov 14, 2007 | 01:47 AM
tinman143's Avatar
20-25mm
Old Nov 14, 2007 | 01:48 AM
tinman143's Avatar
the wheel specs should be on a sticker inside each wheel if yr lucky...
Old Nov 14, 2007 | 03:18 PM
by15vc's Avatar
i would run 25 all around..even push to 30 if you're willing to roll the fender, i'm running 20f 25r right now and there's still some room to play with
Old Nov 14, 2007 | 06:22 PM
i believe after some research the offset is +45
