Choosing new tire size??
Old Dec 14, 2007 | 02:11 PM
tightvpkid's Avatar
My past post about at uneven tire wear and everyone told me to get new tires...so here i am aboutt o buy new rear tires only. I read alot and everyone loves the Falken 452's. I was wondering for the g35 coupe w/ 19 inch rim what is a good size to buy? stick to stock size 245/40/19? my car is lowered right now so the tires are tucked in...i think its a 2 inch drop from factory. Should i go any wider keep it the same any input..? any other tires you recommend and anywhere you recommend buying it from? Thanks for the help guys
which one is better
TOYO T1R's?
or Falken 452's or are they the same....Toyo seems to be more pricey worth it or no?
i use this car to commute so yea..
BTW only my rear is worn out so is changing the rear tires only going to be ok?
Old Dec 14, 2007 | 04:43 PM
DrrSeuss's Avatar
Only changing the rears is not going to be a problem. I love my Falken FK 452s...I'm running 255 40 19s in the rear with no problems. There perfect for daily driving and the best thing I like about them is they don't have the annoying road noise.
Old Dec 14, 2007 | 04:44 PM
joe603's Avatar
I love my setup with Toyo Proxies!
245/35-19 front
275/35-19 rear
Old Dec 14, 2007 | 07:28 PM
Beebo's Avatar
^^^^ 275 is not safe at all on a 8.5 rim... its too wide for the rim...
go with Falken... i am very disappointed with my Toyo T1R's
i have 245/40/19 front and 255/40/19 rear on my stock 19's and its great
stock sizes are 225/40/19 front 245/40/19 rear
Old Dec 14, 2007 | 10:11 PM
Ferrarimanic360's Avatar
i thought you couldnt fit a 245/40/19 tire on the front without rubbing?
Old Dec 17, 2007 | 12:45 PM
tightvpkid's Avatar
what was wrong with the toyo? from what i seen they don;t make the front OEM size for the falkens no?
Old Dec 18, 2007 | 02:16 PM
Beebo's Avatar
it fits fine i never rub...
The side walls are weak, and they don’t stick to the road that well at first, they wear too fast and the road noise when they wear is horrible...
dont get the OEM sizes...
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
