Will this tire size combo be ok?
Old Jan 7, 2008 | 04:54 PM
SVH's Avatar
SVH
These are on factory 19" rims:
Front: 235/35-19 (2% smaller than the stock 225/40-19)
Rear: 245/40-19 (Same size as stock)
They do not make this tire (Falken FK-452) in the stock front size. The 235/35 is as close as I could get.
I just want to double check that this will not **** off the computer in any way. It doesn't seem like it should, but this would be an expensive guess if it did!
Thanks,
Sonny
Old Jan 7, 2008 | 05:01 PM
lowrider's Avatar
245/35/19 would be better.
Lou
Old Jan 7, 2008 | 05:07 PM
Silver5656's Avatar
wow 245 on the front and rear? might change the handling characteristis
Old Jan 7, 2008 | 05:11 PM
SVH's Avatar
SVH
Lou,
You're right...it is a closer match. I guess I didn't consider that size because I figured that the 245mm tire on the front rim would be too wide without also plus sizing the rear? Will it "look funny"?
Thanks,
Sonny
Old Jan 7, 2008 | 10:43 PM
lowrider's Avatar
Nope, will fit the 8" wide wheel just fine and will also look and drive just fine. It will reduce some of the built in understeer. Handling will be more neutral.
Lou
Old Jan 14, 2008 | 07:21 PM
TwilightG35Guy's Avatar
i'm lookin at getting new tires for the oem 19"s i just picked up but i want to go with 275 in the rear. i know the tires can fit the wheels but will the offset cause this size of tire to rub the fender? i don't want to roll the fenders just to fit some fat tires though.
any knowledge out there?
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
