wheel spacers
Old Jan 18, 2008 | 04:58 AM
socalvq35's Avatar
Question wheel spacers
was wondering how far i should space out my wheels for a
more aggressive look.
5 10 or 15 mm?
just wanted your guys' input
thanks in advance
Old Jan 18, 2008 | 09:39 AM
waijai's Avatar
i.love.gold
Just measure the distance between fender and tire. wider is better
Old Jan 18, 2008 | 12:43 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
5 10 or 15 mm?
thanks in advance
what wheels are you running...stock 19's? if, not then what are specs/offsets?
Old Jan 18, 2008 | 04:06 PM
Jason@Riverside's Avatar
+1!
Old Jan 18, 2008 | 04:28 PM
socalvq35's Avatar
yea the stock 19's
Old Jan 18, 2008 | 04:39 PM
az1anbeethoven's Avatar
for the stock 19's i would go for a 10mm spacer
Old Jan 18, 2008 | 04:41 PM
socalvq35's Avatar
for both front and back?
Old Jan 18, 2008 | 04:43 PM
yea, i would do front and back with a 10mm...remember the rear is a little wider than the front, thats why the rear offset is +33.
Old Jan 18, 2008 | 04:44 PM
socalvq35's Avatar
i see.. thanks a lot man
Old Jan 18, 2008 | 04:51 PM
DRG35R's Avatar
20 Year Member
do not use a 10mm spacer front and rear. you will be disappointed with the results. I would go with 15mm F and 20mm R. if you want to be a bit more aggressive then 20mm F and 25mm R, but no more than that.
Old Jan 18, 2008 | 04:53 PM
redlude97's Avatar
I would personally go 25mm all around
Old Jan 18, 2008 | 05:14 PM
socalvq35's Avatar
anyone have pictures of 25mm or 20mm?
eledin's Avatar
Is there a difference from brand to brand or does it really not matter provided you get the size you want.
If it does matter, do you guys have brand recommendations?
I need to find a pair of 7mm ones to clear the front brembos.
Old Jan 18, 2008 | 05:18 PM
redlude97's Avatar
Depends on the spacer type you are looking for. For bolt on, I would stick with eibach and project kics, for spacers with replacement studs, eibach, h&r and ichiba would be good choices
Old Jan 18, 2008 | 05:26 PM
tightvpkid's Avatar
which one is better bolt on or replacement studs?
