Project Kics spacers needed
Old Jan 26, 2008 | 08:28 AM
Triji's Avatar
If you go with adapters w/ 15 / 20mm will there be enough thread left on the bolts to tighten the wheels securely? The lug nuts would not have as much to bite onto and keep secure.... What are your thoughts Jason?
thanks.
Old Jan 26, 2008 | 11:32 AM
redlude97's Avatar
thanks.
why would there not be enough threads left?
Old Jan 26, 2008 | 11:43 AM
Jason@Riverside's Avatar
thanks.
If you purchase any spacer Eibach or H&R, they come with LONGER HUB BOLTS. 5mm spacers come with longer hub bolts, 10-20mm spacers come with even longer hub bolts...
If you get the ADAPTERS you will bolt them directly onto the existing hub bolts. and the new adapters will have their own set of hub bolts sticking out of them...
This is what wheel adapters look like...
weither it is H&R or EIBACH, they include nuts to secure the adapter to the wheel hub, and you use your existing lug nots to bolt the wheel to the adapter.
Old Jan 26, 2008 | 02:03 PM
spin117's Avatar
Jason can u pm me that price for either the kics or the eibachs in 15/20mm for the oem 19's (including the hub ring)
Old Jan 26, 2008 | 02:09 PM
spin117's Avatar
http://www.evasivemotorsports.com/me...e=KICS_HUBRING
What is the bore of our oem 19's?
Old Jan 26, 2008 | 02:23 PM
spin117's Avatar
NM I got it 66mm
http://www.jtuned.com/content/templa...=426&zoneid=16
Old Mar 13, 2008 | 01:04 AM
shdowflare's Avatar
I need 15mm spacers in the front and 20mm in the rear.
Where's the best place to buy em? I've heard to avoid eBay. Which vendors are selling these here on G35driver?
Thanks!
B
Old Mar 19, 2008 | 02:48 PM
Steel Blue's Avatar
Jason - I am looking for teh H&R 15/20mm wheel spacer. What is the best way to get in contact with you?
Old Mar 19, 2008 | 11:43 PM
LightsOut's Avatar
SIETESG
i just purchased some from autoanything.com
used a promo code.
if you purchase from their site. view under 350z as your vehicle to select the spacers.
Jason at riverside dont work their no more. he is no longer a sponsor. he goes by jasonnnn something like that.
contact tony@riverside he is the guy to go through now.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
Albanian122
Aug 1, 2015 08:41 PM
newg37
Jul 26, 2015 09:32 AM
