G37 Wheels FIT G35 Coupe?
Will the G37S Wheels fit the G35 Coupe 03-07'? Please dump your knowledge in this thread. Some are saying you will need spacers. Specs are 19x8.5offset - 43mm Front & 19X9 offset - 45mm Rear. And of course the bolt pattern is 5x114.3. Thanks!
they should fit, but they will be really tucked in under the fender. you would need to get 10mm spacers to get them to the stock 19" g35 wheels locations. if your goin to go with spacers you might as wel get 20 or 30 mm spacers instead of 10mm spacers to bring them out farther and give them a more flush look.
why go to so much trouble to put on the g37 wheels? it's not like they're anything spectacular (they're not even forged). why not just go with g35 OEM 19's or aftermarket wheels, especially since G37 19" wheels are not exactly cheap?
