How will this fit on my 2003 g35 coupe
Old Feb 12, 2008 | 08:11 AM
nycityinsomniac's Avatar
19in work vsxx
5x114
19"8.5 +38 225/35/19 federal tires
19"9.5 +45 265/30/19 federal tires
I can get them with tires for like 2k used.
will i need spacers?
Old Feb 12, 2008 | 09:29 AM
FlyingLumpia's Avatar
yeah probably 25mm, but if you dont want them let me know I will get them for my sedan.
Old Feb 12, 2008 | 09:33 AM
ill let you know for sure!
Old Feb 12, 2008 | 10:08 AM
waijai's Avatar
i.love.gold
weak offsets, I wouldn't bother if they're going on a coupe
Old Feb 12, 2008 | 10:39 AM
Calvin's Avatar
Overglorified Altima
it'll look terrible on a coupe.
don't even bother.
wait for a 9.5/10.5 setup.
Old Feb 12, 2008 | 12:04 PM
Thanks for the info guys i will look elsewhere. No point in spending tons of money if its not going to be perfect.
Old Feb 12, 2008 | 03:25 PM
umm what about me?
Old Feb 13, 2008 | 04:07 PM
KapVu's Avatar
19"8.5 +35
19"9.5 +35
If you got spacers for that, would that fit on a coupe or will it still look to tucked.
Old Feb 13, 2008 | 10:29 PM
KapVu's Avatar
anyone?
Old Feb 13, 2008 | 10:46 PM
Nismo G's Avatar
The oem 17" rims have a +32 offset (i believe) so that should give you an idea of how they will sit with the fenders...
if you are going 8.5 in the front then you want your offset between +22 and probably +5
If you are going 9.5 in the rear you want your offset between +22 and +15
^These offsets will give you a pretty "flush" look (no space between the fender and the tire).
If you are going 9.5 in the front then you want your offset between +28 and +22
If you are going 10.5 In the rear then you want your offset +28 and probably +22
^these offsets will give you a pretty "flush" look as well.
Remember with offsets (for the coupe) the higher the number the more tucked away from the fender they are going to be. The lower the number the closer to the edge of the fender they are going to be.
IMO the best set up is
Front - 19x9.5 +22 with a 255/35/19 tire
Rear - 19x10.5 +22 with a 295/30/19 tire (you will have to roll your fenders) if you dont want to roll your fenders then go with a 275/35/19 tire.
-Sean
Old Feb 14, 2008 | 01:07 AM
KapVu's Avatar
^^ That's really great info. Really explains a lot to me. I'll keep that in mind.
But I don't get what spacers do. Do you subtract from the offset of the wheel? For example, if I have a +35 offset and get a +15 spacer, would the offset be around +20 or would it add and get an offset of +50?
I'm seeing how to get +35 offsets to fit.
Old Feb 14, 2008 | 01:17 AM
Correct, johnny tell him what he won.
Old Feb 24, 2008 | 10:51 AM
louieallthetime's Avatar
what about in my situation?? Im wanting to run 18"x8.5" (front), 18"x9.5" (rear) Off Set: 20mm (front), 25mm (rear) on my 03 coupe...235/40 (front) 275/40 (rear) how is this going to fit/look?? http://cgi.ebay.com/ebaymotors/18-WH...em130199885907
TWASkyliner
Feb 8, 2020 08:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Chattzx
Jul 17, 2015 11:23 AM
