Offset help/questions
Old Feb 18, 2008 | 06:09 PM
Infinite1's Avatar
20 Year Member
Hello all you wheel offset masters!
I'm in the process of purchasing rims (SSR SP1 Professors) and I just need a bit of help with doing the offsets. I've done the searching and have seen the calculators but i'm not sure if the offset I came up with is aggressive or not aggressive. So rather than rack my brain I'd figure I'd ask...The wheel specs are as follows:
19x9 (f) +24 ET? (not sure what that means)
19x10(r) +24 ET
I'm trying to get a 4.5" to 5" lip in the front and rear. Will this work? Is positive ET the center is closer to the strut and negative ET its farther away from the strut? Thanks for the input everyone! I'm sorry but when it comes to offsets i'm plain confused.
Infinite1
Old Feb 18, 2008 | 06:45 PM
redlude97's Avatar
your lips won't be even close to 5" with those sizes and offsets
Old Feb 19, 2008 | 09:25 AM
Infinite1's Avatar
20 Year Member
What do you suggest? I know your setup is 8.5/9.5 if i'm not mistaken. What are your offsets though? I was hoping it would be aggressive but i don't want too much tire stretch either. Thanks for your help!
EDIT: I found this link on a importer for SSR wheels.
http://www.more-japan.com/SSR/sp1/19inch.php
Old Feb 20, 2008 | 11:58 AM
Infinite1's Avatar
20 Year Member
bump for more advice!
Old Feb 20, 2008 | 12:21 PM
redlude97's Avatar
To get a 4.8" lip, you are going to have to run a 19x11+11 or a 19x10.5+5 with a SL disk, this is pretty aggressive IMO. If you can settle for a 4.3" lip, then run a 19x10.5+18SL or a 19x11+24, as for the front, it will depend on if you need BBK clearance or not
Old Feb 20, 2008 | 12:41 PM
Infinite1's Avatar
20 Year Member
Thanks redlude for the help! Shows i'm not an expert on offsets by any means....How big of a lip will a +24 yield on a 19x10 (r) ? The numbers you posted are pretty aggressive! I think i've may have been too enthralled with wanting a deep lip but not really understanding the limitations. That's quite a bit of tire stretch as well! I don't have a BBK so i guess i can get away with a bit more in the front.
Thanks again for the help!
Old Feb 20, 2008 | 12:48 PM
redlude97's Avatar
3.3"
Old Feb 20, 2008 | 01:03 PM
Infinite1's Avatar
20 Year Member
Thanks! That isn't so bad...Now I just have to see if that will work on a 19x9 in the front...haha
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
