How thick of a spacer can you use before you need longer lug studs?
Old Mar 13, 2008 | 12:18 AM
  #31
shdowflare's Avatar
So - not to hijack - but which should I go with:
15mm front, 20mm back
20mm front, 25mm back?
I'd prefer built-in stud extensions. I've got the Ray's 19s, dropping the car 1" on my new BC Racing Coilovers. What do you guys think I should run?
Thanks!
B
Old Mar 13, 2008 | 01:31 AM
  #32
redlude97's Avatar
Thanks!
B
20mm/25mm for a pretty normal setup. Personally I would go 25/30mm and roll the rear fenders
Old Aug 29, 2010 | 05:48 PM
  #33
psychomotif's Avatar
This might sound like a stupid question,
but I bought aftermarket rims that are hitting my Brembos on the 03 g35 coupe.
1st question: Are Ichiba hubcentric spacers safe?or spacers in general.
2nd question: I might need 15mm or 20mm in the front, is 15mm too little and/or 20mm too much?
3rd question: Will my factory bolts/lugs protrude from the spacers? will i have to cut them off?
4th question: Do i go with all this mod or sell the new aftermarket rims?
PLEASE HELP.
Old Sep 19, 2010 | 07:43 PM
  #34
prinzzz's Avatar
i also need help. I put on g37 wheels on my g35coupe. i've been running this setup for abt 8mnths now but now i want to put on spacers. I'm not looking for anything aggressive, is 10mm or 15mm better? which ones should i get as these wheels use's the shank lugs.
Old Sep 19, 2010 | 07:47 PM
  #35
I did much research on spacers, they are not safe.
Apparently they cause premature wheel bearing problems. Also you have to keep tightening the spacers every like 500 or so miles.
They every make the ride uncomfortable.
Old Sep 19, 2010 | 08:22 PM
  #36
prinzzz's Avatar
i think i remember reading that somewhere as well. i'm thinking of them now as a possible solution to my driver side camber arm scrapping the inside of my rim when im reversing left. i don't kow if my camber arm is bent or if it's offset problems. maybe someone can shed some light on this for me. are camber arms easily bent?
Old Sep 19, 2010 | 08:31 PM
  #37
Calvin's Avatar
Overglorified Altima
Old Sep 20, 2010 | 01:09 AM
  #38
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
^^ I'm with you on that one Cal.
This has been discussed many times before on this forum. I'll let you come to your own conclusion tho.
seagrasser
May 3, 2022 09:43 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
