Sedan rims/tires: FINAL
Old Mar 31, 2004 | 02:25 AM
nuttyprof's Avatar
ok, once and for all in plain english please:
i searched and searched and dont understand wtf is going on with the sedan rims/tires. my questions are these:
1. what is the widest rim I can put on the front and rear with offsets. (17, 18, & 19 inches)?
2. is it good for handling to stagger, or put widest possible on front and match that for rear?
3. or, is it the tire size that really affects handling (stagger or widest possible on front and match with rear)?
sorry guys, but i totally didnt understand that sedan fitment chart. it makes no sense to me...its easier for me just have a range (ie. 35-45 offset on 8 inch wide rim)
anything else you guys feel should be finalized once and for all in plain english, please add.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
JWT popcharger + Z-tube
Stillen True Dual Exhaust
6-wire ground kit
Old Mar 31, 2004 | 01:20 PM
3point5SE_Auto's Avatar
Re: Sedan rims/tires: FINAL
go measure your car. that is the easiest way to learn. if you don't understand the fitment chart then you need to learn. in order to learn you need to research and study.
it sounds like you are going to be dropping $2-3k in the near future. I recommend you never do that on somebody's "word".
if you have questions about your research and stuff, feel free to PM me and I will give you my phone number. But it is not worth the time to rewrite the fitment chart.
Best thing is go to a wheel shop and actually fit several different size wheels on your car.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, HyperGround Kit, Magnaflow resonator.
Old Mar 31, 2004 | 02:51 PM
nuttyprof's Avatar
good idea. thanks
G35S 6MT
Technosquare ECU
6-wire ground kit
Old Mar 31, 2004 | 07:33 PM
dholly's Avatar
nutty - here's a good explanation on offsets and how to measure for wheel space, etc.
http://www.rsracing.com/tech-wheel.html
Hope that helps.
2004 | 6MTs | Diamond Graphite/Graphite
Upstate NY
derres
Aug 28, 2015 03:27 PM
saskicker32
Aug 11, 2015 02:12 PM
tiguy99
Jul 26, 2015 01:39 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
Ninjay16
Jul 20, 2015 01:21 AM
