OEM 19" with 265/30/19 Tires
Old Mar 29, 2008 | 01:56 PM
  #31
OCG35's Avatar
funny how people ask questions and ask for help, then debate the answers they get from very knowledgeable people!
Something that seemed to be overlooked through the thread (and was asked about once) is that the series (30 in this instance) is the percentage of the width... so 30% of 265mm is not the same as 35% of 245mm… it’s nearly ¼” diff… and of course the overall diameter is off.
Gdupsedan and redlude97 offered very good advice. IMO it should have been given more consideration.
Old Mar 29, 2008 | 04:24 PM
  #32
badtziscool's Avatar
I'm running 235/35 and 255/35 on oem 19" wheels and I really like them. They're cheaper than the OEM setup and I think it looks a little bit better because of the slightly shorter profile.
Old Mar 30, 2008 | 05:59 PM
  #33
minus500's Avatar
Another informative post. In case you didn't notice, I got the info I was after. I wasn't debating anything either. I asked a question, got an answer, and went from there. I really wanted to understand WHY it wouldn't work and WHY proper biasing is important. Gdupsedan was very helpful and I actually learned something here. THANKS Gdupsedan!
Also, Redlude only said that the tire was shorter and was just arrogant in the process. But, yeah that was helpful. Kudos to you for describing the aspect ratio which was already addressed. I'm not trying to be rude but I don't think you had to post here.
Old Mar 31, 2008 | 01:22 PM
  #34
OCG35's Avatar
Old Mar 31, 2008 | 05:11 PM
  #35
Dan_K's Avatar
40 would be optimal in the rear, but would look like a truck tire in the rear especially with an oversized tire/undersized rim.
I am running a 35/30 FR setup on aftermarket wheels, and my VDC went off the first mile I drove it. But, the car ran normally and after that initial alarm, the VDC has not gone off since. I am only running 30 in the rear because they don't make a 35 in 295 or 305 widths in the tires I like.
Old Mar 31, 2008 | 07:06 PM
  #36
redlude97's Avatar
30 series in the rear is the correct aspect ratio for a 305 width on a 19" wheel
Old Mar 31, 2008 | 09:46 PM
  #37
minus500's Avatar
Old Apr 1, 2008 | 03:12 AM
  #38
j-velocity's Avatar
i used to ran 235/35R19 and 265/30R19 on OEM 19.
it will fit on OEM 19"
Old Feb 15, 2010 | 11:25 PM
  #39
sfsergey's Avatar
^ would that setup 235/35r19 front and 265/30r19 rear set off the vdc?
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
