Brake squesks when not applied
Old Apr 3, 2004 | 01:49 AM
neildawg's Avatar
Lately I have been noticing a load distinct intermittent squeak coming from the right front wheel of my 6MT coupe. The odd part, is that I hear this squeak when the brakes are not being applied. I can be traveling at any speed and the frequency of the squeak increases w/ increasing speed. When I apply the brakes, the squeak stops and occasionally resumes when I release the brakes. Are they're any brake experts in the house that can help diagnose my problem?
Since it's intermittent, it is difficult to reproduce for the dealer. In fact, I have already taken the car in once, but have been unable to duplicate the problem for them. I need more education before my next visit to the dealer. Thanks for all your help....
Old Apr 3, 2004 | 06:21 PM
BlackObsidianX's Avatar
Re: Brake squesks when not applied
read it somewhere in the manual long time ago....squeaking noise when brake is not applied means your brake pad needs to be replaced.
I'll try to find that section in the manual again...and post the exact quote in there.
Old Apr 3, 2004 | 06:30 PM
redwillow's Avatar
20 Year Member
how many miles you got?
Did the dealership check the wear on the brake pads?...Or have any idea what may be causing it?
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, double 15% tint
Old Apr 3, 2004 | 08:18 PM
section 2-15 in manual:
"Brake pad wear warning
The disc brake pads have audible wear warnings. When a brake pad requires replacement, it will make a high pitched scraping sound when the vehicle is in motion whether or not the brake pedal is depressed. Have the brakes checked as soon as possible if the warning sound is heard."
Old Apr 4, 2004 | 01:33 AM
neildawg's Avatar
I've got a little over 10k miles on the car so I find it hard to believe its the pads. At least, i haven't heard anything regarding premature pad wear on the Brembos.
When I visited the dealer, one of the service advisors took a lap around the dealership w/ me to see if we could replicate the problem. Unfortunately, we couldn't reproduce it--intermittent problem. He offered to put the car on the lift and see if he could notice anything, but he just shined an flashlight here and there and said "there is no problem." I think i'll take the car back in and have them thoroughly inspect the brakes.
The dealer said he would be "the envy of all porsche owners" if he could stop the squealing of high-performance brakes. Riiiiiiiiiiiiiiight...what a load....
Old Apr 4, 2004 | 01:35 AM
neildawg's Avatar
Thanks BlackObsidianX---I'll keep that in mind when I visit the dealer next.. I should open up that manual.. :-)
Old Apr 4, 2004 | 04:01 AM
Rob_G35's Avatar
In Search of Magic
I had that problem when I replaced the pads on my car. Turned out that the shield behind the rotor was touching the rotor for some reason. When I bent it back the problem dissapeared.
2003 CB Coupe 6MT
Z-tube
Stillen Hi-flow
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
alinero718
Sep 27, 2015 09:35 PM
vamarris
Sep 26, 2015 12:56 PM
