Wheel Size Calculator / Rim Weights
Old Nov 10, 2003 | 07:55 PM
EL_PAALO's Avatar
Re: Wheel Size Calculator / Rim Weights
Also, decreasing OD will increase engine rpm at a given speed, and vice versa.
BTW: couldn't edit my previous post - is there some trick i'm missing?
http://www.wheelspecs.com
Old Nov 10, 2003 | 11:38 PM
ryoken's Avatar
A larger OD would increase speed to a point, but the added weight of the tire is going to make the engine work harder to spin it up, reducing your acceleration, and also having a negative effect on top speed.
As for 40/17's v. 45/19's.. that's mostly true, but you have to take the whole tire size into consideration to get the outside diameter. For instance, a 225/40R17 and a 145/45R19 are only 0.2% off -- but your statement is mostly true, as those who upgrade to larger rims usually go same-or-wider, not narrower.
As for editing posts.. it's a forum bug. Sometimes some users can't -- the problem is known, but the solution still evades the admins.
Old Dec 4, 2003 | 10:00 AM
G35Papa's Avatar
gr4n23
I have a set of 245/45/18's on the rear of my Sedan.
Im going to get the Eibach Pro Kit to drop it one inch BUT..before I do that Im going to have to put some 225/45/18's or I will rub all over.
I was also considering keeping my setup and just rolling the lip on the fender.......pondering setup still.
Old Dec 24, 2003 | 10:57 AM
cmpterman2's Avatar
I got tired of continually checking different tire sizes using the miata calculator. So i made an excel spreadsheet of all the different sizes of tires and rims and compared it to the original size on the sedan. I figured some of you out there might find this useful.
Tires with diameter within 1% of the original size are colored green. Those within 3% are colored yellow.
<a href=http://www.people.cornell.edu/pages/apd6/TireSizeComparison.html> Tire Size Comparison </a>
Also, if you want to download the spreadsheet to change the initial value, here it is:
<a href=http://www.people.cornell.edu/pages/apd6/TireSizeComparison.xls> Tire Size Comparison SpreadSheet </a>
It essentially tells you the useful tire/rim sizes for a particular vehicle given the original tire sizes.
Enjoy!
<P ID="edit"><FONT class="small"><EM>Edited by cmpterman2 on 12/24/03 08:05 AM.</EM></FONT></P>
Old Dec 29, 2003 | 01:01 AM
T_bull's Avatar
thanks dude
Old Dec 29, 2003 | 02:21 PM
Carlos3186's Avatar
thats really usefull thanks man. do u think u could make one for the coupes as well. the stock rear coupe wheel is 245/45/18 and the front wheels are 225/45/18
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Dec 31, 2003 | 10:53 AM
cmpterman2's Avatar
Here are the tire size comparisions for the coupe:
<a href=http://www.people.cornell.edu/pages/apd6/G35CoupeFrontWheels.html>G35 Coupe Front Tire Comparison</a>
<a href=http://www.people.cornell.edu/pages/apd6/G35CoupeRearWheels.html>G35 Coupe Rear Tire Comparison</a>
Old Jan 9, 2004 | 01:18 AM
g35bh4ve's Avatar
I hope this site is also useful. Please check it out.
http://toy4two.home.mindspring.com/offset.html
Old Feb 3, 2004 | 05:31 PM
nimnix's Avatar
Anyone know the rim weights for the 18" wheels or where I can find that info?
Infiniti G35 Coupe - Twilight Blue/Graphite/5AT/18"/Nav/Bose
Zchickz
Old Feb 3, 2004 | 05:41 PM
ryoken's Avatar
<hr></blockquote>
Go back to the first post in this thread and pay attention to the available links. Either that, or look for the manufacturer's website, especially if it's a fairly new rim.
Old Feb 4, 2004 | 08:47 PM
chefkbk's Avatar
OK, I'm not the smartest guy in the world, as far as how to interpret this chart. If I want to put an all season tires on the front of my coupe with the 18 inch package, what size can I go to without rubbing, or messing up any of the computer stuff? Currently it is the 225/45/18, and I want to find a size that will fit in a Mich Pilot A/S. They make it for the OEM rear size, but not the front. Thanks for the help!
<P ID="edit"><FONT class="small"><EM>Edited by chefkbk on 02/04/04 05:48 PM.</EM></FONT></P>
Old Feb 28, 2004 | 10:24 PM
SoCaLG35Mashin's Avatar
I made a spreadsheet to show the overall tire diameters and profile heights for 19/20" tires in comparison to the stock diameter of the coupe. Hope it's useful.
2004 G35 6MT Coupe
Black/Willow
Purchased Dec 20, 2003
Old Mar 30, 2004 | 08:44 PM
TXREFI's Avatar
I have the stock 18" wheels with 225/45 front and 245/45 rear. I would like to keep the stock 18" x 8" but put as wide a tire as I can on the stock 18" x 8", will 265/45 on rear and move the current rear 245/45 to the front work?
Will the stock 18" wheels hold the 265's or will they ballon out?
<font color=black>2003 G35 Coupe, Blk/Blk</font color=black>
<font color=red>Frisco, TX</font color=red>
TXREFI G35
Old Mar 31, 2004 | 02:50 PM
TXREFI's Avatar
Thanks for all the replys, from the advice it sounds like the safest sizes are 245/40/18 & 255/40/18.
The only other question is should I go with 255/40 or 255/45 in the rear, does the varience from front and rear add together?
Meaning 245/40 show (-1%) and 255/45 (1.3%) Totaling 2.3% between.
Although just adding the mm is appear the 245/40 & 255/40 are closer. Example: stock 225/45= 101 1/4 mm sidewall & 245/45=110 1/4 sidewall, a 9 mm difference.
If I go with 245/40= 98 mm sidewall and 255/40= 102 mm sidewall, a 5 mm difference. But if I go with 245/40= 98 mm sidewall and 255/45= 114 3/4 mm sidewall, a 16 3/4 mm difference ( way off stock).
If I did this correctly it appear 245/40 & 255/40 are my best options.
TXREFI G35
Old May 7, 2004 | 04:06 PM
  #30
G35rookie's Avatar
Can you repost the spreadsheets? I couldn't down load or view them.
Thanks.
