Can we remove this????
Old Apr 6, 2008 | 11:38 PM
Infinite1's Avatar
20 Year Member
Hello all...I'm not sure if this is the correct section but here goes...
I was wondering if we can remove the "deadbolt" (lack of a better term) from the front wheel hub of the coupe? The reason i'm asking is that i was mounting my new rims on and it seemed that got in the way? In order tor it to mount on my wheel hub I took that extra bolt off...I was told that bolt was just to keep you from rotating your tires from the back to the front...Anybody know if removing this affects the rotor or something else? Thanks!
Old Apr 6, 2008 | 11:42 PM
Beebo's Avatar
you can remove it...
Old Apr 7, 2008 | 12:14 AM
jdmgee35's Avatar
Yeah it can be removed. I had the same issue before... Just use a socket wrench on it, real easy to take off.
Old Apr 7, 2008 | 09:58 AM
SukaZenki's Avatar
Yeah you can remove that. It's only an alignment pin for your stock rims.
Old Apr 7, 2008 | 10:00 AM
Infinite1's Avatar
20 Year Member
PHEW!!! Thanks guys for the confirmation! I was a little adamant so i figured i'd ask the experts out there. Thanks again!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
dcsbh1
Oct 1, 2015 03:15 PM
