Another sedan on Coupe 19" but with stock height
Apr 15, 2008 | 02:08 AM
Lowered with htechs, 19 coupes, no fender rolling, no rubbing. Click my link below for pic.
Reply 0
Apr 15, 2008 | 04:56 AM
I've got a 03 sedan with stock suspension and coupe 19's. Yes the rears stick out a little further, and yes they will rub going over speedbumps on 245/40-19s. I first tried 255/45-19s on my rears, and they rubbed a lot. I immediately dropped down to a 255/35-19 and there is no rubbing. I'm also running 245/35-19 on the fronts.
Reply 0
Apr 15, 2008 | 11:49 AM
I'm running 255-35-19 on coupe 19s in the rear with a stock suspension for now, and I only rubbed if I had passengers in the back and hit big dips/bumps. I rolled the fenders in the rear a smidge, and no more rubbing.
Reply 0
Apr 15, 2008 | 11:51 AM
Quote: I'm running 255-35-19 on coupe 19s in the rear with a stock suspension for now, and I only rubbed if I had passengers in the back and hit big dips/bumps. I rolled the fenders in the rear a smidge, and no more rubbing.
^Any pics showing how your tires sit in comparison to the rear fender?
Reply 0
Apr 15, 2008 | 12:10 PM
Quote: Lowered with htechs, 19 coupes, no fender rolling, no rubbing. Click my link below for pic.
are these g or z h techs??? im assuming z
Reply 0
Apr 15, 2008 | 12:46 PM
Here's my 19's with stock height. I have 245/40/19 Nitto Invo tires all around and I have no rubbing at all, even when I go fast through tight turns.
Reply 0
Apr 15, 2008 | 04:05 PM
^^are you running four front coupe-19s?
I thought you could not run staggered on an X.
Reply 0
Apr 15, 2008 | 04:11 PM
Coupe 19s on oem tires. Z front/Coupe rear springs. No rubbin so far. No rear lip fender roll.
Reply 0
Apr 15, 2008 | 04:40 PM
You could run OEM staggered on the X, as long as you maintain same overall tire diameter from front to back to preserve the transfer case. Since rim width differs only by 1/2" from front to back, same size tire fits on both front and rear rims. If you go with a crazy staggered configuration, the wheel/tire weight difference from front to back will certainly confuse the AWD system and you may run into problems. Search for it, there are many threads about this topic.
Reply 0
Apr 15, 2008 | 08:05 PM
Nice pics Texan1! Your G looks slick. I am planning on lowering it and roll the fenders as well. You are absolutely right though, my bottom front end has always scraped when going down steep driveways lol.
Quote: Here's my G with stock sport springs. I have decided not to lower the rear, but I am rolled on the lips for good measure. I will lower the front 1/2" . It has a 2" gap in rear and will have a 2 1/4" or 2 3/8" gap or so in front. It looks much better in person in terms of being aggressive. On pics, people zero in on the gap and recommend you "slam" it Its not a track car, will never be a track car and the roads and steep drives will be tough for aggressively lowered cars...heck the aero-front bumper is already 1" lower than stock. So being a bit practical on ride-height.
Right now coilovers are not in the picture, but who knows in the future.
Rays Forged Coupe 19s | Kumho Ecsta SPT -- (F)245/35/19 -- (R)255/35/19
Reply 0
Apr 15, 2008 | 08:08 PM
Jeff92se and mshabelm, thanks for posting your pics!!!
Reply 0
Quote: You could run OEM staggered on the X, as long as you maintain same overall tire diameter from front to back to preserve the transfer case. Since rim width differs only by 1/2" from front to back, same size tire fits on both front and rear rims. If you go with a crazy staggered configuration, the wheel/tire weight difference from front to back will certainly confuse the AWD system and you may run into problems. Search for it, there are many threads about this topic.
well, good to know. Looks like you did your research and its paying off!
Quote: Nice pics Texan1! Your G looks slick. I am planning on lowering it and roll the fenders as well. You are absolutely right though, my bottom front end has always scraped when going down steep driveways lol.
Thanks!
Reply 0
Apr 15, 2008 | 08:28 PM
Just snapped some pics. It looks much better now...
First is the stock 18", the rest are with the 19".
Another sedan on Coupe 19" but with stock height-img_2394.jpg   Another sedan on Coupe 19" but with stock height-wheels2-005.jpg   Another sedan on Coupe 19" but with stock height-wheels3-001.jpg   Another sedan on Coupe 19" but with stock height-wheels3-004.jpg
Reply 0
Apr 15, 2008 | 08:55 PM
^looks fantastic, soo much better/cleaner/sharper.
what is your tire size again?
Reply 0
Apr 15, 2008 | 09:00 PM
  #30
I want my coupe 19s now 17s suck
Reply 0
