Tire Sizes
Old May 4, 2008 | 05:19 PM
Ronjon17's Avatar
Tire Sizes
Hey Guys,
I purchased a used '04 G35 back in September '07. The front tires badly need replacing. When I started doing some research I found that the previous owner must have changed the wheel sizing. Talked to a couple guys, who gave me different suggestions, but I figured I would consult the pros first.
The fronts are Falken RT615 245/40R18
The rears are Yokohama YK520 245/45R18
These are definitely different from OEM Spec. I am relatively new at this so maybe some recommendations would be helpful.
Here's what I want in order of importance:
-An aggressive looking tire with the stock 18" rims.
-Summer performance in terms of cornering and stability is a must.
-Tire should also perform well in the rain. I have problems hydroplaning right now.
I don't particularly want to change the rears as the tread wear is still in pretty good condition but I have heard bad things about slip with the Yoko YK520 and I have noticed my slip light goes on and I get slip shifting from 1st to 2nd during aggressive driving. That being said, again I don't want to but I will consider changing the rears.
Can you guys recommend a specific tire size? And maybe some suggestions on tires themselves?
Old May 5, 2008 | 01:08 PM
Mountian Pirate's Avatar
coupe or sedan?
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
