need help, VDC acting up
Old May 25, 2008 | 11:43 PM
Mitsuko's Avatar
so driving home one day i took an exit ramp a lil too fast and vdc kicked in, no biggie. but since then, it started goin off more and more even on turns that i am definitely not sliding on. its gotten to the point where even going slow it kicks in, which now i consider a little dangerous since if someone is behind me and it suddenly brakes my car on a turn, not good. funny though, its only when im not in gear and riding the turn out. if i gas it through the turn and accelerate, it doesn't go off.
what do you guys think it is? any help is appreciated.
i DID though just get new rear tires, and they are standard size 245/45/18. but this never happened with having the tires for a week. only after that first incident. i sort of dont want to turn vdc off all the time, it has saved me a few times so i like it a little. i hope its not a differential problem. thanks ahead of time.
Old May 26, 2008 | 01:36 PM
releasedtruth's Avatar
What kind of tires are they? When I got new rears and they weren't of the caliber the car demands, the VDC was pretty unhappy with me until I remedied the situation.
Old May 26, 2008 | 01:46 PM
elayman's Avatar
also if you have different size tires on the front and back or different brands i've heard it kicks in
Old May 26, 2008 | 01:47 PM
mIKE's Avatar
Check your tires, and also check your lugnuts.
Old May 26, 2008 | 03:31 PM
Mitsuko's Avatar
the rears actually grip a lot better than the ones i replaced it with, so i'd say an even higher caliber. i didn't change the size though, kept it the standard 245/45/18. I guess it is though a tire thing, just sort of glad its not a differential issue.
I'll try new tires in the front.
Old May 27, 2008 | 08:53 PM
PTownG's Avatar
turn it off
Old May 28, 2008 | 10:16 AM
amurph01's Avatar
my G35 w/17's has been doing the same thing since i replaced the rear tires with tires I think are better than stock not worse.
it is supposed to be a fairly common issue when you replace only the rear tires, which wear more quickly so it comes up quite a bit. there doesn't seem to be a lot you can do short of turning VDC off or replace the front tires w/ the same brand.
Old May 28, 2008 | 03:37 PM
TurboDreamzG's Avatar
i am having same problem with mine. i put 285s gforce on my rears and got my new coilovers and went to test them out on a sharp turn to see how it handles and the vdc kickcs in and it sucks, will shuttin off the vdc work? i heard that it will over ride even if you have it off? i hate that thing. can't even haul *** around corners now.
Old May 28, 2008 | 03:45 PM
Drewer's Avatar
Check your brake fluid levels everyone.
VDC is a braking system, although posing as a "limited slip" system. I've seen it so many times that a low brake fluid level + corning = sloshing in the reservoir, and if the system thinks the fluid is low leading to non-function, it'll flash the VDC light, and then that plus the SLIP lights will both stay on until you shut the car down.
I have a 245 40 18 and 275 40 18 setup and have never had any VDC problems.
Anywais. . .hope this helps!
Old May 28, 2008 | 11:13 PM
nas4a's Avatar
Mine did that exact same thing right after I got new tires. The tires were different than OEM sizes, but still in the same ratios and such. It stopped after a few times and never happened again.
I think the VDC has to readjust or something.
Old May 30, 2008 | 04:46 AM
EndlessWaltz112's Avatar
Drewer
+1
This has been happening to me all last week to now. My VDC, RAS, SLIP, and BRAKE light all turned on every time I drove after a while. I checked the brake fluid and it was low. Also an indication if you need new brakes. Winded up doing a brake flush and changing all my brakes after a year or so.
Still have stock set up if that helps anyone. So like what Drewer said, check your brake reservoir! Brake fluid being at minimum does make a difference.
Old May 30, 2008 | 01:13 PM
Klubbheads's Avatar
turn it off.
MThawkins86
Oct 24, 2015 02:07 AM
markbilo
Sep 30, 2015 01:33 AM
