New Wheels????
Old May 27, 2008 | 07:46 PM
snavematt's Avatar
just a sedan
New Wheels????
Ok, so my Brembo GT kit is too large for my Sevas S22's. Should I go Wilwood BBK or get new wheels? I know Iforged and HRE would clear, but dropping $4k on new wheels with tires is not what I want to do. So should I go Wilwood or change my wheels? I do like my Sevas, but the Brembos are hot. I know Coupe 19s work, but can I use other wheels that are coupe offsets on my sedan?
Thanks
Old May 27, 2008 | 08:05 PM
Locksmith's Avatar
Get new wheels.
Old May 27, 2008 | 08:07 PM
snavematt's Avatar
just a sedan
Ok but what Im looking for is what will clear, suggestions on wheels, prefer 20s staggered, will go 19s if needed
Old May 27, 2008 | 08:23 PM
G35Papa's Avatar
Def wheels......your budget?
Old May 27, 2008 | 08:27 PM
snavematt's Avatar
just a sedan
G papa, it depends, I would love HREs or Iforged, but it all depends on what I can get for my sevas.
Old May 27, 2008 | 08:39 PM
G35Papa's Avatar
Scratch out HREs....almost no one can afford them lol
You will always take a good hit on a set of aftermarket rims no matter what brand they are unless you just plan on waiting it out to get what you really want for them.
iForged and DPE def make rims to accomodate BBK. There are also some concave wheels that allow for BBK as well but you give up a lip. Depends on what look and style rim you want.
Made for BBK
http://iforged.com/us/wheels_category.php?CatID=11
Sorry..I'm biased
Old May 27, 2008 | 08:46 PM
black_sedan's Avatar
can you not use a spacer?
Old May 27, 2008 | 08:52 PM
snavematt's Avatar
just a sedan
not enough space for a spacer large enough. these are 355 mm rotors so it sits higher. Maybe I could get a different offset in the front. But hell, I dont know shoat about wheel offsets and stuff like that
Old May 27, 2008 | 10:01 PM
do you have any idea what offset your wheel is? i know its probably either +35 or +40. either way, i've seen another member Flyinglumpia running the same wheels with either a 10mm or 15mm spacer in the front.
10mm should be plenty to clear a BBK.
Just a thought if you wanna hold off on buying those new wheels right away.
Old May 27, 2008 | 10:03 PM
ah.. basically the spacer will lower your wheel offset.. ex: if you have a +35 offset and add a 10mm spacer, you should be now at a +25mm offset.
Old May 27, 2008 | 11:29 PM
FlyingLumpia's Avatar
Check the back of the wheel, what I remember it should say 20x8.5 with a et of 40 or 25. If its 25 then I suggest getting new wheels, if its a 40 you could run a spacer.
Old May 27, 2008 | 11:59 PM
Locksmith's Avatar
Save up and get a set of volks with high pad fitment to clear those brembos.
Old May 28, 2008 | 12:18 AM
snavematt's Avatar
just a sedan
The sevas fronts are +25, rear +40, Im good in the rear, its the fronts
Old May 28, 2008 | 12:29 AM
well, i guess you can scratch the spacer idea... if the wilwoods is cheaper go with that then. unless you're just looking for an excuse for new wheels.
i really like the look of the Iforged Daytonas or Work Varanzas.
Old May 28, 2008 | 12:32 AM
snavematt's Avatar
just a sedan
I love the Iforged Daytonas, but that price is killing me, maybe I will go that way. The Wilwoods are cheaper than what i paid for the brembos
