Toyo T1R FTL
Old Jun 21, 2008 | 11:18 AM
  #46
oooooooooooooq's Avatar
^^ what the hell did you just say?
Old Jun 21, 2008 | 12:07 PM
  #47
mIKE's Avatar
Originally Posted by Derzigster
I run Toyo T1R's and I think they are much better than the OEM Bridgestones. These are alot wider than the original and I run ~32-34 PSI in them. I would never run more than 35 PSI in them though.
not apples to apples if you're running wider tires.
With same width tires, the RE050A will run circles around the T1Rs.
how many of you have actually run the re050's in the same size as you are running the t1r's? I think alot of you would change your tune if you compared them on a similar basis
Quoted for emphasis.
Imagine if you could get RE070s in 275s.... Course everyone's be burning through em in 4000 miles... but that'd be a DAMN good 4000 miles...
Old Jun 21, 2008 | 05:14 PM
  #48
ResIpsa's Avatar
Originally Posted by shabarivas
LOL @ replacing tires... stock tires = 10K miles backs are at 0 and fronts at about 10-20%...
on to 4 t1Rs and 22K miles - fronts have NO inside tread left... lmao replace fronts....
And of course... new rims = 4 new tires.... all w/ in 26K
So these Toyo's are going to last 22K miles...great...I guess
Old Jun 21, 2008 | 05:52 PM
  #49
OCG35's Avatar
Originally Posted by G35Rider92649
WTF, i just bought T1R's yesterday!!!! Same exact sizes!!! Ahh oh wells, everything has a bad review, thanks anyways for posting your experience O.P, but I paid 900 for all 4 of mine balanced/installed/wutever crap it is, so its all good
WTF here too!!! I'm getting T1Rs installed next week
Soft sidewalls?.... damn it! Why am I hearing this now???
Old Jun 21, 2008 | 11:51 PM
  #50
Klubbheads's Avatar
Old Jun 22, 2008 | 02:53 AM
  #51
OCG35's Avatar
I don’t know what a RE050A is... but my base model overpriced Bridgestone Turdanza's where crap!
BTW - Whats up with Riverside Infiniti?... I PM'd Mike and Rick a couple days ago and no response...
Old Jun 22, 2008 | 02:54 AM
  #52
B L U E S L A T E's Avatar
Honda Accord
Just call them, Mike. They usually are packed with PMs and some don't even get through. lol
Old Jun 22, 2008 | 02:58 AM
  #53
OCG35's Avatar
I called Tustin...
Old Jun 22, 2008 | 07:57 AM
  #54
Nismo G's Avatar
Originally Posted by Klubbheads
decent tire but the downpart is that u can not rotate from side to side. So if u have over -2.0 camber like mine, im guessing they will take about half the time of T1Rs to wear out.
A friend of mine had those and Toyos before on his GTI and GTO, he told me the performance of the Toyos are better.
Why could you not cross rotate them?\
-Sean
Old Jun 22, 2008 | 10:25 AM
  #55
ResIpsa's Avatar
Toyo T1R and Price = FTW
Regardless of my previous posts, the Toyo's are the best value on the market.
OCG35, please post your review of the Toyo's as a counterpoint. What brand are you replacing?
Old Jun 22, 2008 | 11:27 AM
  #56
OCG35's Avatar
replacing Kumho ecsta asx... only replacing because I have new wheels (upsizing)... The Kumhos were real good in the beginning - but now they dont seem to grip as well in the rear (and there's still plenty of tread).
I've been looking forward to the Toyos, but now I'm concerned that they are going to be mush on hard cornering
I'll post review after I install and running on 'em for a couple weeks...
Old Jun 22, 2008 | 12:29 PM
  #57
ResIpsa's Avatar
I just dialed my D-Specs down another full turn (firmer) to compensate. This setting would be bone jarring on the Bridgestones but seems to really help with the Toyo's. It's been about 600 miles (yeah, I drive a lot) and I'm starting to get used to them.
Getting those D-Specs was the best decision I have ever made.
Tokico D-Spec
Old Jun 22, 2008 | 01:51 PM
  #58
Klubbheads's Avatar
-Sean
i never said i would cross rotate them. Rotating side to side means taking the RR tire off of the rim and putting it on LR rim, RL tire off of the rim and putting it on RR rim, RF tire off of the rim and putting it on LF rim and LF tire off of the rim and putting it on RF rim.
Reason: Much more life from ur tires.
Old Jun 22, 2008 | 02:57 PM
  #59
Hexxum001's Avatar
^^^In other words, you are flipping the tires. That's what I just did. After about 13,000 miles, my inner tread was pretty worn on my fronts. The rears are in good shape though. So I had them flipped. The fronts should last a couple thousand more miles and the rears longer than that.
Old Jun 22, 2008 | 03:19 PM
  #60
Nismo G's Avatar
You said can't rotate them from side to side...I know what cross rotating is...any tire that is staggered and directional you have to cross rotate. What i interpreted from your OP was that you can't rotate them at all once they are mounted or is that what you are trying to say?
I cross rotated my toyos T1R because you can't just rotate them...
-Sean
