17" coupe wheels on a sedan = Bearing noise?
Old Jun 25, 2008 | 06:49 PM
STLTHSDN's Avatar
so after picking up my 17" staggered coupe wheels from the powder coating shop and getting the Kuhmo ecstas reinstalled i mounted the wheels and much to my chagrin i am getting a WICKED amount of road noise and bearing noise and grisnding in the brake that i can feel in the wheel and the pedals. im guessing its most likely the change from 17x7 +42's to 17x7.5 +35 with the wider tires. but is it possible its the tires? maybe theyre mounted on teh opposite sides of how the previous owner had them. any suggestions? the brakes are also BRAND new pads and rotors that were just changed last month and it ran like a top til i changed the wheels. im not rerally big on the look of the +35 fronts anyway so i may put them on the back and get my 7" stocks pc'd to match and sell the other +33 rears with the other 2 +42 &" to a Silvia owner or something. but anyway, any suggestions. could i have maybe bent a heat shield while installing the wheels or is this a common problem with aftermarket or wider wheels? the car has 98K Miles on it. so its getting to be on the verge of its bearing expectency anyway.
so...bearings? ****ty tires? brake problem? wheels to wide?added stress?
Old Jun 26, 2008 | 10:21 AM
obender66's Avatar
Put your stock wheels on and see what happens. Lots of us run wider/larger wheels and bearings will not fail just overnight.
Check brake shield-it is easy to bend, it may rub rotor indeed.
rezendvous420
May 31, 2020 01:26 PM
Joshua615
Aug 31, 2015 12:29 AM
teamghost
Jul 28, 2015 04:52 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
cyrus32
Jul 18, 2015 06:22 PM
