Spring/Wheel Gurus: Do i need to roll my fenders?
Old Jul 7, 2008 | 02:43 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I have that setup of 10.5" +22 TE37s in the rear. With Nitto 275/35/19 tires, it would just barely rub in hard cornering. I never heard anything, but I could see markings on the tire where it hit the fender. This was on stock height.
After I lowered the rear about 1.4", it was rubbing pretty badly with cornering. I got my fenders rolled for $50, and the problem was solved. I recently had my rear camber kit installed. With -1.5 degrees in the rear, there's still plenty of clearance. I'll get 285/35/19 Michelins next time.
Old Jul 7, 2008 | 02:44 PM
Day177017's Avatar
^^^ Interesting.
I've never really cornered hard, but i've never rubbed on my 285/30's. Where'd you go for your fender roll? Reputable shop? Good work?
Old Jul 7, 2008 | 03:22 PM
surfquikslver's Avatar
walmart.
Old Jul 7, 2008 | 06:05 PM
E_K's Avatar
E_K
Originally Posted by Day177017
^^^ Interesting.
I had it done by daytona350z on my350z.com. He does excellent work. He's done several cars, and knows what he's doing. I figured it would cost me about $40 to rent the tool, so for only $10 more, I could have someone do it who's done several before.
Old Jul 8, 2008 | 12:47 PM
Day177017's Avatar
Thanks
Originally Posted by surfquikslver
walmart.
And no thanks
Old Jul 8, 2008 | 12:48 PM
broke_as_ajoke's Avatar
i have stock springs.. and i can tell u that u should roll ya fenders.. cuz i'm rubbing bad on my driver side rear
Old Jul 9, 2008 | 03:34 AM
bellzebul's Avatar
like redlude said, u dont need to roll ur fender if u have correct offset for ur rims.
i run 285/30 19, drop 1.4 n never rub.
Old Jul 9, 2008 | 08:32 AM
dreamcatchr's Avatar
to give credit to redlube, offsets are critical... i'm dropped on z h-techs, running 285x30 and dont rub at all... my offset is 24... hope it works out for you...
Old Jul 10, 2008 | 12:58 PM
Day177017's Avatar
My offset is +22 on my TE37's 19x10.5 in the rear with 285/30's.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
