Wheels spacers on g35 coupe opinions please
Old Jul 3, 2008 | 08:09 PM
Realtor's Avatar
Hello,
Wanted some opinions on wheels spacers for a g35 coupe. I am concerned with safety since the wheels I am considering buying are the wrong offset and need a 10mm spacer to correct them. What are some opinions..are spacers safe? Any comments on certain brands of spacers(i.e. which ones to get and are of good quality)?
Thanks for the input.
Old Jul 3, 2008 | 08:11 PM
O HELLA OEM's Avatar
do you have the stock 17's,18's,or 19's?..if you have the stock 18's do 25mm all around for the flush look.if you have the stock 19's id say 20mm front 25mm rear..as far as brands..you should get like ichiba,h&r,definetly get the hubcentric..some say spacers are safe some say they get vibrations ..i hope i helped somewhat..GL
Old Jul 3, 2008 | 08:32 PM
fwdsux's Avatar
I have run spacer/adapters in the past with no issues.
I am currently running an H&R 15mm spacer on the rear on my wheels with no issues, no vibrations, nothing. Just remember that with any spacer over 8-10mm, you have to make sure to get the extended studs with them. My wheel specs are 19x10.5 rear, +23 offset (so the spacer brings that down to +8) with 285/35 with rolled fenders. I'm not sure if it rubs cause I just had the 285's put on today, but with 265's & 275's I was fine.
Go aggressive with it, I love how my car sits right now.
And I have a brand new set of H&R 15mm for sale, with the studs if you're interested
TWASkyliner
Feb 8, 2020 08:00 PM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
Cskeet
Jul 19, 2015 12:38 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
