Road Noise when Slowing down
Old Jul 7, 2008 | 02:17 PM
austinm22's Avatar
I have a '05 G35 Coupe and when I slow down I seem to be getting alot of road noise. Is this typical or do I have something out of whack you think?
Thanks!
Old Jul 7, 2008 | 02:24 PM
chilibowl's Avatar
Thanks!
Its either your tires or you may need an alignment.
Old Jul 7, 2008 | 02:26 PM
BlueDevilBAMF's Avatar
Or you could have a slightly bent rim causing uneven tire wear.
Old Jul 7, 2008 | 03:44 PM
austinm22's Avatar
now that you mention that I actually had replaced a rim in the front right from clipping a curb, the repair shop that did it said the alignment was fine but it seems to pull to the right (same side we replaced the wheel on) so i think you might be right about the alignment. Ill take it somewhere else next time...Thanks guys!
Old Jul 7, 2008 | 11:17 PM
N/A Project's Avatar
-2006 IP GT350-
Your tires mang!
Old Jul 9, 2008 | 10:39 AM
G35fromPA's Avatar
Tire aging will cause increased road noise. As the tread blocks wear down, the designed-in frequency effect to reduce tread noise degrades.
Old Jul 16, 2008 | 04:04 AM
bythabay's Avatar
bad wheel bearing...
Old Jul 22, 2008 | 03:35 AM
chrissportg35's Avatar
i had the same problem. Since i put on a new set of tires....problem solved
Old Jul 22, 2008 | 12:21 PM
austinm22's Avatar
to followup with you guys i took it to a repair shop to have it looked at and they told me something like the arm was slighly bent but not bad. What you guys think?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
9tray turbo
Sep 29, 2015 10:22 PM
