Need advise on spacers...
Old Jul 19, 2008 | 10:30 AM
reverse's Avatar
Question Need advise on spacers...
I know nothing about spacers, so need some advice... What size would I need to fill the wheel well a lil bit more. Don't want that lowrider stance though...
5zigen SportsEngines
19x8.5 f +25 (245/35)
19x9.5 r +25 (275/30)
RS-R springs (1F, 1.1R) - Not sure if this relevent
Old Jul 19, 2008 | 11:48 AM
clinthammer's Avatar
do you own a coupe or sedan?
those offsets are for a coupe!
Old Jul 19, 2008 | 04:57 PM
reverse's Avatar
04 coupe.....people on the forum suggested spacers. i look'd them up and noticed the different sizes. researched them, but really didn't get diffinitive answer as far as my setup.
Old Jul 20, 2008 | 11:55 AM
redlude97's Avatar
I would personaly run 20mm spacers all around
Old Jul 22, 2008 | 10:18 AM
jlin615's Avatar
I have 20mm(f)/25mm(r) on OEM 19", they are perfectly flushed. Just did some calculation comparing my setup against your wheel specs. If you went with 10mm all around, it'll only be 1mm(f)/6mm(r) wider than mine.
relude97, I'm still new at this offset thing, is my calculation right?
Old Jul 22, 2008 | 01:28 PM
reverse's Avatar
the OEM are x8 front, x8 1/2 back (im guessing)...so 20mm do the job? is there a write up on how to install?
Old Jul 22, 2008 | 01:57 PM
jlin615's Avatar
Yes the OEM 19 is 8.0in(offset 30) for front and 8.5in(offset 33) for rear. 20mm/25mm did the job for me.
Install is easy if you have tools. Simply just removing wheel and place the spacer over the hub, will require more work if you dont get the spacers with built-in studs.
Old Jul 22, 2008 | 05:41 PM
kenchan's Avatar
for those offsets and widths i'd do 10mm all around for a flush look.
Old Jul 22, 2008 | 06:08 PM
jlin615's Avatar
Hey that's what I said!
Yes, we think you should go for 10mm all around, 5mm spacer for your setup would be almost pointless.
Old Jul 22, 2008 | 06:24 PM
Kidcane's Avatar
+1 on 10mm. Just make sure you dont buy crappy EBay spacers. Get hubcentric and the longer wheel studs.
Old Jul 23, 2008 | 09:23 AM
reverse's Avatar
planning on ordering a set of project kics from HR Autosports. the 20 wouldn't be too extreme would it?
Old Jul 23, 2008 | 09:42 AM
jlin615's Avatar
IMO, 10mm looks the best for your rims, front will look flushed and rear will stick out a little tiny bit. If you have 20in rims with step lip (Work meister or T1s), then 20mm spacers will look fine.
Old Jul 23, 2008 | 10:07 AM
reverse's Avatar
Cool..thnx
Old Aug 27, 2008 | 06:29 PM
reverse's Avatar
last question.....thinking about going 15mm?
esotericrider
Feb 14, 2022 07:19 AM
Dmill86
Sep 6, 2015 08:14 PM
bjo16
Aug 4, 2015 09:52 AM
CJay
Aug 1, 2015 03:57 AM
