Tire rumble?? What do you all think???
Old Jul 25, 2008 | 07:30 PM
GRRRRR's Avatar
I am experiencing a lot of noise from my front end recently that sounds like the tires. The tires are about 2 years old but the tread is solid since I have only 11k on them.
Is it possible for the tires to age and make noise while the tread is still good? For what it is worth I live in a warm climate (Charlotte NC). Thanks for your input - I appreciate it!!
Old Jul 25, 2008 | 10:02 PM
jhurst's Avatar
How old are the tires? Should be a 4 digit number on the tire that tells the age (if it a 3 digit number get rid of NOW!).
Old Jul 25, 2008 | 10:04 PM
RaginRaj11's Avatar
my front tires made a lot of noise on the higway but i got an alignment and the noise went away.
Old Jul 25, 2008 | 11:51 PM
NoirKyouto's Avatar
I only wish I could get 11k on a set of tires lol... 8 or 9k is about all I can squeeze out of ZR's.
If tread is good, the tire isn't degraded (turning brown and cracking, ect)... try getting it rebalanced and verify the alignment. Also, it's possible your rotor(s) are warped.
Also, performance tire's ride performance typically degrade horribly over life. They're awesome new, crap when they're about done.
Old Jul 26, 2008 | 01:53 AM
NyG35fL's Avatar
tires shouldnt be making noise. i would say just replace them.
Old Jul 26, 2008 | 03:14 AM
hyperlite21's Avatar
ask the dealer about your ball joints on your camber arms i had that problem and they replaced them
Old Jul 26, 2008 | 07:45 AM
GRRRRR's Avatar
Thanks
Thanks for your ideas/suggestions. I appreciate it!!!!
Old Jul 26, 2008 | 09:16 AM
Boston's Avatar
To the OP's original question, yes you can get plenty of road noise from tires even though the tire has significant tread life left.
Old Jul 26, 2008 | 09:21 AM
Iceman8's Avatar
^ +1 I have Pole Positions on the front and they make horrible noise. I have about 2k left on them, but Im gonna cut it short and buy new ones.
Old Jul 26, 2008 | 09:32 AM
GRRRRR's Avatar
Tire date?
Tire date? Don't know if I know what that is, but will look....
Old Jul 26, 2008 | 11:34 AM
bocatrip's Avatar
Usually when the front tires hit around 7-8000 miles, depending upon the tread design, they start to get noisey on the fronts. The inside fethering is usually the cause and there is not much you can do about it. The noise will get louder over time. My friend had the Pilots and the noise was so loud after 12,000 miles it was almost deafening. Coupes and tires issues go hand in hand. The best thing to do in the future is research a tire that might make the least noise for you. I went back to the RSAs on my Coupe with 17s and after 6,000 miles they are still quiet. I'm crossing my fingers.
Old Jul 26, 2008 | 12:10 PM
GRRRRR's Avatar
Ok
Thanks - very informative....
Old Jul 27, 2008 | 12:14 PM
Ktm.Moto's Avatar
They could be cupped on the inside? Thats what was the problem with my coupe. Replaced them all and got an allignment and so far so good. Good Luck!
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
