tire size?
Old Aug 4, 2008 | 03:34 PM
joesexy's Avatar
tire size?
can i put 275 in the back with out rub
Old Aug 4, 2008 | 03:44 PM
04NismoV35's Avatar
Loaded question.....I currently have 275/35/19 on coupe 19's and IT DOES NOT WORK! Tons of rub, I am experimenting w/ my sedan. However if had aftermarket wheels I might not have the same problem.
Need more info, do you have a coupe or sedan? Factory or aftermarket wheels?
Old Aug 4, 2008 | 03:51 PM
twin001's Avatar
Stock height or lowered?
You can go 255/40-19's without messing up your VDC.
Old Aug 4, 2008 | 06:03 PM
lowrider's Avatar
When you drop some more info, you might get some more answers. There's not enough here to give you an answer.
Lou
Old Aug 4, 2008 | 08:20 PM
nghiars's Avatar
^^^we need more info to give you a good answer.. im running 275/35/19 with aftermarket wheels on my coupe and dropped on df210 and didnt rub because of EXTREME NEG camber.... soon as i get my alignment it will rub.
Old Aug 5, 2008 | 02:24 AM
joesexy's Avatar
my bad i have an 04 coupe stock wheels but i want 20' .and its not dropped .now . whats the best wheel size without rub
Old Aug 5, 2008 | 02:47 AM
Don@TireOption's Avatar
Shouldn't be a problem considering you are stock height.
Old Aug 5, 2008 | 03:39 AM
hyperlite21's Avatar
+1 i have 275's stock height no rub
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
