need some info on wheels
Old Aug 5, 2008 | 12:03 PM
seth22's Avatar
i have an 03 sedan i need some help with wheels i am looking at getting 18x8 and 18x9 in the rear. ok the people at the wheel place are telling me that the rear will rub. i see all of these other sedan with staggerd fits so how does this work or do yall just deal with the rub. please help
Old Aug 5, 2008 | 12:24 PM
G35sedan03's Avatar
a lot of it depends on the offset and face of the wheel. post the rest of the information on them so we can better help you. we already know the sizes, we need to know the offsets, front and rear of those wheels, brand and model, just to see what we are dealing with.
Old Aug 5, 2008 | 01:06 PM
seth22's Avatar
here is a link to the wheel i am looking at. they said run a 40 offset all the way around
http://www.wheelfire.com/scontent/Wh...724&CheckFit=1
Old Aug 5, 2008 | 04:44 PM
G35sedan03's Avatar
if that setup is +40 all around and you go with conservative width tires, 225 f and 255 r, it should fit no problems. now you didn't say if you are lowered or at stock height. the more info you give about your setup, the better we can answer, but intially it seems good to go.
Old Aug 5, 2008 | 04:50 PM
seth22's Avatar
its stock right now i might lower it later but its stock for right now
Old Aug 5, 2008 | 04:52 PM
seth22's Avatar
so what tire should i run, or let me put it this way what tire would you run with stock height on frornt and back, and what tire would you run if it were to be lowered ( if the tires need to be changed)
Old Aug 5, 2008 | 04:54 PM
G35sedan03's Avatar
also i noticed that the package they are offering you comes with 235/40 and 265/35 tires. those sidewalls are too small, the sizes to go with to maintain your overall circumference the same are 235/45 and 265/40. that will get you under 1% overall circumference just by going off those sizes.
Old Aug 5, 2008 | 04:59 PM
seth22's Avatar
ok so i orderd the wheels now i just have to find tires. so you saying i need to run a 235/45 in the front and and 265/40 in the rear?
Old Aug 5, 2008 | 05:03 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
or you can run 245/40 front and 275/35 rear.
-GP-
Old Aug 5, 2008 | 05:11 PM
G35sedan03's Avatar
to maintain the overall circumference, the closest to stock, yes. you can try other sizes, but the key is you want to get your overall circumference (wheel and tire) as close to the stock circumference as possible so your electronics, like VDC and speedometer and such are happy.
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
vstypicals
Jul 20, 2015 10:55 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
