20" Neeper Moxy Wheels - 295/30 in the back?
Old Aug 9, 2008 | 04:17 PM
ashu911's Avatar
Hi Guys,
After some trial and error with wheel decisions, I need one final input on this:
offset front and back is +24mm.
front lip is 2 inches, back rim lip is 3.5 inches
Rims made by Moxy- Fronts are 20x 8.5 Backs are 20 x 10
Toyo tires Front size 97w 255/35/zr20 Back tires size 101w 295/30/zr20
My car is an 03 G35 Coupe - no brembos.
Just need a final input on this. I dont plan on lowering the car and i'm hoping they would sit flush with the wheels without any rubbing - even with 4 people.
Thanks,
Ash
Old Aug 9, 2008 | 04:43 PM
Gilley's Avatar
285/30/20 will work well on the 20x10s.
Old Aug 9, 2008 | 04:50 PM
ashu911's Avatar
Sean,
So would 295/30 be pushing the envelope? I saw a forum where someone has these in the back but there wasn't any offset mentioned.
255/35 is ok for fronts?
Thanks,
Ash
Old Aug 9, 2008 | 05:03 PM
nghiars's Avatar
the 255s in the front will be fine... i would go wit 285 in the rear.... if youre not lowered u will not rub
Old Aug 9, 2008 | 05:16 PM
ashu911's Avatar
Is that for 285's or 295's?
Old Aug 9, 2008 | 05:44 PM
Gilley's Avatar
The 295's may rub. 285 will be a better fit on the 10 inch wide rims. It will have a good look. Plus, 295's are harder to find.
255/30/20 is the froper front tire size. 255/35/30 is too tall up front and is actually taller than the rear tire. It will work if you really want to use the 35 series.
Old Aug 9, 2008 | 05:48 PM
Sbeck's Avatar
I have 285's on my 20x 10 rears. No reason to go any larger on a 10 inch rim.
Old Aug 9, 2008 | 06:16 PM
ashu911's Avatar
Hey Guys,
Thanks for the quick response. The reason I want to know about this particular setup is because I am buying it used. They're actually new and not "used" since the buyer decided to go with other wheels. It's worth it for me for $800 lesser than market value.
I just dont want to have it put on and it rips the s*** out of everything.
Thanks!
Old Aug 9, 2008 | 10:21 PM
Gilley's Avatar
You are buying the rims with the 295 tires already on them?
Old Aug 9, 2008 | 10:30 PM
ashu911's Avatar
Yeah, they have the 295's already on them. I was going to buy them as a set.
Old Aug 10, 2008 | 04:11 AM
Triple8Sol's Avatar
You'll want 255/30 to stay in spec, and match the rear 295/30. Seriously.
Old Aug 10, 2008 | 09:41 AM
Gilley's Avatar
Try it with the 295s. You may have to roll your rear fenders.
Old Feb 10, 2011 | 02:44 PM
black_gst's Avatar
Sorry to bump an old thread guys, but i have these same wheels on my 05 sedan except i have 20x8.5's front and back, and id like to buy a pair of the 20x10's to throw in the rear and i have been trying to find out if fitment for wheels is the same for both the coupe's and sedans. and i cannot find offset info on these wheels either.
any help would be great,
thanks guys!
-Adam
rezendvous420
May 31, 2020 01:26 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
rping
Jul 26, 2015 09:53 PM
apintojr
Jul 23, 2015 10:52 AM
