volk offset help
Old Aug 21, 2008 | 02:36 PM
gnav80's Avatar
volk offset help
im looking to get a set of volk sf wining on my 06 coupe. im trying to figure out what the proper offset should be for 19x9.5 front and 19x10.5 rear. im a noob to the tuner world and could really use some help. . thanks
Old Aug 21, 2008 | 07:40 PM
redlude97's Avatar
we need more information. BBK clearance, tire sizes, alignment settings, fenders rolled etc. It depends on which volks you want also, as the offsets available are limited
Old Aug 22, 2008 | 01:40 PM
gnav80's Avatar
im not sure what BBK is. i was thinking of putting them on a 245/35/19 front and a 275/35/19 rear tire. and no my fenders are not rolled. my coupe is way OEM
Old Oct 13, 2008 | 09:59 AM
lilindienplaya's Avatar
did you ever get an answer to which offset you need for the volk SF winnings, im thinking of getting a set 19's but i dunno what widths or offsets to get right now its completly stock, please give me some advice.
Old Oct 14, 2008 | 03:56 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
BBK = BIG BRAKE KIT
Old Oct 14, 2008 | 04:00 PM
DRG35R's Avatar
20 Year Member
you guys need to provide more info so people can answer your questions. see previous post above from redlude97.
there are many different fitments available for this car and it all depends upon what type of equipment you have on the car or are going to put on i.e. BBK. also how aggressive of a fitment do you want or not?
Old Oct 14, 2008 | 04:02 PM
35gsleeper's Avatar
This is very simple..get your fenders rolled and fitment size should be +17 front, +18 rear..drop it on what ever coil or spring setup u like and just like that the car is done
Old Oct 14, 2008 | 04:03 PM
r0csfinest's Avatar
i have sf winnings with 19x9.5 +19 19x10.5 +17
Old Oct 14, 2008 | 04:25 PM
RXmotors's Avatar
Yep offsets 19 F and 17 R. Clears Big brake kits
Lip size is 19 9.5 is 67 mm
Lip size is 19 10.5 is 92 mm
Old Oct 15, 2008 | 09:11 AM
DRG35R's Avatar
20 Year Member
I have Ro_Ja R2-5 19x9.5 +19, 19x10.5 +19 with 245-35 and 275-35 T1R's which is a fairly aggressive fitment.
this will clear BBK's, does not rub and there is no need to roll fenders.
I would definitely go with 9.5F and 10.5R. your offsets will be good anywhere from +17 to +24 front and rear for good flush to fender line fitment.
hope that helps a little.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
