What tension should i torque my lugs at?
Old Aug 31, 2008 | 09:37 PM
sayheycoop's Avatar
The wrench in the trunk for changing a flat...
got new locking lug nuts. what tension should i torque them to?
thanks
Old Sep 1, 2008 | 12:45 AM
molidor01's Avatar
Lug Nuts
It should be 80 ft lbs if im not mistaken?
Old Sep 1, 2008 | 12:48 AM
sayheycoop's Avatar
thanks. bump just to make sure
Old Sep 1, 2008 | 12:50 AM
Texasscout's Avatar
My sedan says 85 lbs/ft
Old Sep 1, 2008 | 12:56 AM
gary c's Avatar
Just tight enough....!
You're NOT mistaken it's 80 ft lbs, and never let anyone use an impact gun
while installing your wheels....ever!
Gary
Old Sep 1, 2008 | 10:34 AM
SiouxFallsG35's Avatar
Coupe Factory Service Manual:
Old Sep 1, 2008 | 08:11 PM
sayheycoop's Avatar
Wow awesome thanks!!
Old Sep 3, 2008 | 03:28 PM
sayheycoop's Avatar
is the wrench in the trunk designed to torque at 80 ft/lbs? bc i just realized that the torque wrench i own does not have that high of a capacity.
Old Sep 3, 2008 | 03:44 PM
sayheycoop's Avatar
bump
Old Sep 3, 2008 | 03:51 PM
GreenGoblin's Avatar
The goblin resurrection
you need a new tourqe wrench
Old Sep 3, 2008 | 03:54 PM
sayheycoop's Avatar
so the wrench in the trunk is not designed to torque at 80 ft/lbs?
Old Sep 3, 2008 | 05:09 PM
Boston's Avatar
^the wrench in your trunk, assuming it's the OEM lug wrench is not a torque wrench.
brianuc4
19
Apr 10, 2020 02:12 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
reaper76
Sep 20, 2015 11:59 AM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
