Winter Tire/Wheel question
Old Sep 11, 2008 | 09:42 AM
medgar's Avatar
Let me start by saying I have used the search button and have not found everything I am looking for. Let me start by saying I have a Base 2003 sedan with 17's. I am trying to get a safe winter setup for the Michigan winter without breaking the bank. Here are my questions:
1. Can I buy 15 rims and make up for the diameter difference with a taller tire? Someone told me 15's may not clear the rotors. 15 tires and wheels seem much cheaper than 17's.
2. Can I reuse my all seasons come spring if I have them taken off my current rims and put 17 inch snows on my current rims. If so I would buy new rims for my all seasons in the spring and leave them on there.....or can I keep switching them back and forth from the same rim?
Any suggestions would be greatly appreciated. After getting stuck last year on a slight incline I don't want that to happen with my 13 month old son in the car.
Old Sep 11, 2008 | 11:13 PM
Seymore's Avatar
Can't help you there, I don't know if they'll clear.
Certainly you can reuse them in spring. Store them in a dry place, in tire bags if you can, stacked no higher than 4 and they should be in the same condition that they were before you stashed them away.
You can swap them back and forth as often as you like. I suppose there' s a small risk of scratching a rim or marring/cutting a tire each time you swap, but it's pretty darn low if the mechanic knows what he's doing.
Old Sep 12, 2008 | 09:49 AM
medgar's Avatar
Thanks for your help. I think I will just use the stock rim for both seasons. The rims are not in perfect condition anyway. Thanks again.
Old Sep 14, 2008 | 11:20 AM
medgar's Avatar
Tirerack's preferred winter tire package for my 03 sedan is 16's. They recommend the cheap steel rims and 205/65/16 Blizzaks. These should clear my stock rotors if they recommend them..yes?
Old Sep 17, 2008 | 01:42 PM
pjames's Avatar
16s will clear, some 15s may, i tried my old ford 15's, didn't fit because of the way the wheels were made (the corners of the folded square in the center had about 1/16th of an inch interference with the caliper.)
Old Sep 18, 2008 | 01:06 PM
harrisot's Avatar
I use 16s with Blizzaks on my 03 sedan. I paid an extra $25/wheel to get their cheapest alloy wheels rather than use steel. They work great.
Old Sep 18, 2008 | 01:11 PM
harrisot's Avatar
I may add that it doesn't hurt to have an extra half inch of sidewall you get with the 16s when driving around in a Detroit winter. We used them for 2 years in the northern suburbs (Troy/Auburn Hills) and didn't worry about any of the potholes.
Old Sep 19, 2008 | 09:28 AM
medgar's Avatar
Are you suggesting I go 205/70/16, instead of the recommended size (205/65/16) from tirerack? I looked up that size and only found one winter tire....and the category is light truck.
Old Sep 19, 2008 | 09:42 AM
kvangil's Avatar
You might be able to pick up a good used set from someone on here (or Ebay) that's trying to get rid of there's. I got my 16" rims + Blizzak tires from a G35 driver off eBay for $500 shipped and have used them happily through 2 winters. This will be the third...
Old Sep 19, 2008 | 01:11 PM
harrisot's Avatar
I just meant the 16" rims will give you 0.5" extra side wall vs. a 17" for the same outer diameter.
The tires I ordered were 205/65R16 Bridgestone Blizzak WS-50 ($90ea) mounted on 16x7 Silver Painted Sport Edition F2 ($75ea) in the fall of 2005.
Old Sep 19, 2008 | 01:27 PM
medgar's Avatar
Inflation is a biotch. Now the cheapest rim is $93. I think I will stick with the steel wheels at that price. I just need to switch my 235/50/17 Kumho Ecsta ASX when the snow falls. Stupid me thought just becuase they are all season I would be fine. Not to mention I went wider than stock. Well...you live and you learn. Now I just want something with some good traction. Another thing learned...if I get another RWD car I will make sure it has LSD....versus the one wheel drive I have.
Thanks for the help.
Old Sep 30, 2008 | 08:56 PM
medgar's Avatar
Well.....I decided to go with the Blizzak 205/65/16 with the steel wheels. Tirerack's price is $708 mounted and shipped , plus if you order before Oct 12th you get a $50 debit card from Amex. So I figure $658 for 4 good winter tires and cheap rims is a descent deal. Thanks for the help.
Old Oct 2, 2008 | 05:55 PM
wafun21's Avatar
Hi.. I also have a Infiniti G35 2005 Coupe (no brembo). Do I have to buy the 17" winter wheels and tires? Can I use 16" tires with steel rims because they're cheaper? Any recommendation? I do not know anything about wheels and tires. Just know that my front is 225/50R17 and my rear is 235/50R17..
Old Oct 2, 2008 | 07:46 PM
medgar's Avatar
I went on Tirerack and searched for your car and they did not say 16's will fit. I assumed you had the base model (vs. sport or performance pkg). They recommended 17's....235/50/17.
Jussumman
Dec 22, 2015 10:23 AM
Dmill86
Sep 6, 2015 08:14 PM
cbax
Aug 17, 2015 07:41 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
