Is there any detriment to running 245/40/19 all around?
Old Oct 18, 2008 | 05:03 AM
thejared's Avatar
Would that be bad?
I need tires bad, and found a deal but it's only for the rear size. I'm running 245 in front now, so fit shouldn't be a problem, but will it cause other issues?
On oem wheels of course
Old Oct 18, 2008 | 06:24 PM
RobMD's Avatar
I'm actually very curious about this too but unforuanately dont have the answer either.... was very seriously considering just getting 245'19s x4 for simplisity in ordering tires...
its not easy to find a 225'19" all season tire
anyone know?
Old Oct 18, 2008 | 06:34 PM
CandlestickPark's Avatar
ill Sedan
I'm running 245/40/19s (Falken FK452s) all around on my Sedan with Rays OEM 19s, no problems here.
Old Oct 18, 2008 | 07:10 PM
RobMD's Avatar
running non-factory sizing doesn't void the factory warrenty does it?
Old Oct 19, 2008 | 07:48 AM
thejared's Avatar
i looked into it myself, and theres nothing wrong with it...it will actually help the tires wear better since you can now rotate them at regular intervals.
so i bought 'em.
Old Oct 19, 2008 | 02:40 PM
redlude97's Avatar
so i bought 'em.
Do you have OEM 19's? How do you plan on rotating wheels that are 8" in the front and 8.5" in the rear?
Old Oct 19, 2008 | 04:01 PM
thejared's Avatar
who says I can't put the 8.5 in front? What does it matter.
Or just remove and remount the tires all around
Old Oct 19, 2008 | 06:11 PM
redlude97's Avatar
I guess some people just don't care about handling at all 8.5" in the front and 8" in the rear If you dismount and remount, then you've defeated the purpose of buying nonstaggered for rotation purposes, because people with nonstaggered tires do this already to even out the camber wear which is the most prevelant cause of premature wear
Old Oct 19, 2008 | 09:54 PM
thejared's Avatar
Yeah, those freeways can get pretty twisty... Better keep 'em staggered
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
