winter offset question
Old Oct 24, 2008 | 11:18 AM
freezeg35c's Avatar
I found a set of local winter wheels and tires off a 06 g35 coupe. He did not have the brembos so i dont know if they will clear mine. The wheels are 17x7.5 and the offset is 40. If they will hit I may consider 10 mm spacers.
Thanks in advance.
Old Oct 24, 2008 | 01:29 PM
redlude97's Avatar
depends, brake clearance isn't solely a factor of offset, it has a lot to do with design as well. Without knowing the wheel being used, we can't tell you if it will clear your brakes
Jussumman
Dec 22, 2015 10:23 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
