Hubcentric ring size for Volks
Old Nov 2, 2008 | 08:26 AM
fishmd's Avatar
Hey guys. Sorry if this has been addressed before, but I could not find it in my searching. I got some Volks on the way for my G and I know I will need hubcentric rings to mount them. What is the wheel bore size for the volks. I could not find it, and don't want to wait to order them till I get the wheels so I can measure it. I want to get these puppys mounted right away!
Anyone know? Will the ones with center ring size of 66.1mm and 73mm outer ring size fit right, or do I need a different outer ring size?
Thanks in advance guys.
Old Nov 2, 2008 | 11:15 AM
Boston's Avatar
^ you have the size right, 66.1 - 73.1. I have and run the same size on my Volks.
Old Nov 2, 2008 | 11:24 AM
gary c's Avatar
Why would you assume the hub rings wouldn't come with your wheels? Even
if you purchased them used the rings should be included!
Gary
Old Nov 2, 2008 | 09:57 PM
fishmd's Avatar
you would think so but no. Not everyone uses the rings and I know you technically don't need them, but I would rather use them. Anyways, thanks for the answer.
Old Nov 4, 2008 | 04:35 AM
Triple8Sol's Avatar
Gary
Nope. Majority of new/used wheels DO NOT come with hubcentric rings.
Old Nov 4, 2008 | 04:41 AM
B L U E S L A T E's Avatar
Honda Accord
My Volks came with both hubcentric rings AND tuner lugs.
Old Nov 4, 2008 | 08:37 PM
Triple8Sol's Avatar
Old Nov 5, 2008 | 01:23 AM
az1anbeethoven's Avatar
That is very true. The majority of new wheels make a center bore big enough to fit various vehicles of similar bolt pattern. Therefore, it is up to the end user to find the accomodating hub rings to fit their own vehicle model. The people that received hub rings probably bought it from a vendor which included hub rings to fit your specific vehicle or if they bought used wheels, then they bought it from an individual that had the same model car and included the hub rings that they have used.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
yosip1115
Sep 9, 2015 03:30 PM
Detailed Image
Sep 4, 2015 08:35 AM
UT G35
Sep 3, 2015 03:58 PM
