Will these tires work???
Old Nov 3, 2008 | 07:08 PM
houston05g35's Avatar
Can i use my stock 19inch rear tires(245/40/19) on my new front wheels which is a 19 10.0 +30... and would a 275/35/19 work on the rears which is a 19 11.0 +25. Im lowered on eibach sportlines,,, thanks
Old Nov 3, 2008 | 07:20 PM
redlude97's Avatar
bad idea, your front tires would be way too tall compared to stock, and while not only looking horrendous, would likely cause VDC issues as well. Those tire widths are also going to be quite stretched on those wheels, I would consider running 255/35/19 and 285/35/19 instead for a mild stretch, or 265/30/19 and 295/30/19 for no stretch
Old Nov 3, 2008 | 08:23 PM
Triple8Sol's Avatar
Go with redlude97's latter recommendation. You're running wide wheels, but not the most aggressive offsets, so that should work great.
Old Nov 3, 2008 | 08:30 PM
Thanks for all the info,, and i guess fender rolling is a must????
Old Nov 3, 2008 | 11:50 PM
Don@TireOption's Avatar
Setup doesn't seem too aggressive, so you should be okay without rolling the fenders.
Old Nov 9, 2008 | 01:28 AM
vq35dedriver's Avatar
hey Don I have Volk GTS 19x10.5 +17 or +18 I forgot which one with a 285/35/19 Nitto Invo tire and the fender sits over the tire I'm not dropped at all stock height, spoke to a shop here in WA and he says that a fender roll will not work and it will not fix the problem that I would have to get a wide body kit, and your saying that if this guy will potentially run the same setup but with a 11 inch wide rim and dropped with springs that he doesn't need to roll his fenders. I'm confused why am I having a problem?
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
Popes
Jul 29, 2015 05:07 PM
realtalk21
Jul 20, 2015 09:07 AM
