will these tires rub in the front
Old Nov 8, 2008 | 05:28 PM
ttrank's Avatar
Grocery getter
Originally Posted by Braintree
Are you referring to 235/50/17's, or 235/55/17's??
235 is the width portion of the tire size.
Old Nov 8, 2008 | 08:57 PM
Braintree's Avatar
It seems I'm not asking my question clearly:
1) Will 235/55/17's fit on the 04 sedan? YES or NO
2) Will 225/60/17's fit on the 04 sedan? YES or NO
3) Will 215/60/17's fit on the 04 sedan? YES or NO
No rubbing is what matters to me, the mph being off is inconsequential at this time. I would like to go taller, not wider. The car has not been lowered or altered in any way. Does anyone know or has anyone tried these options w/o problems in their car?
Thanks
Old Nov 8, 2008 | 09:02 PM
maciejk's Avatar
if u go with 235/50/17 like me today, that's as close to the original diameter as u can get 0.2% off if u check tire size calculator http://www.miata.net/garage/tirecalc.html
Old Nov 9, 2008 | 06:10 PM
s.dunn's Avatar
Thanks
I don't think many people have attempted these combinations. Most people attempt to keep their speed-o close to accurate in attempting tire changes in my experience. The most common choice is 215/55 17 for winters if people are changing their rims over or they go stock.
In looking at the tire calculator I think that 215/60/17's 235/55/17's should both fit with out rubbing,but I have not tried them and cannot guarantee your fitment . I think you might be pushing it going to the 225/60/17's. That being said... I don't know for sure.
Why do you want such a huge sidewall on the tire (taller not wider)?
S.Dunn
derres
Aug 28, 2015 03:27 PM
Fireman07603
Aug 9, 2015 06:00 PM
jjohns2711
Aug 5, 2015 08:58 AM
Popes
Jul 29, 2015 05:07 PM
Soumilg
Jul 18, 2015 12:33 PM
