will these tires rub in the front
hi, i couldn't find a specific answer in the search area, quick question will 235/50/17 rub in the front, the guy who sells tires insists they will, the original is 215 which is 2cm narrower than the 235, i turned the wheel both directions while looking at them and i see lots of clearance my sedans isn't lowered or anything like that, just stock
Originally Posted by maciejk
thank you, the guy at that tire shop is a nut
Edit: changed size from 255/50/18 to 255/40/18
Originally Posted by GEE35X
One of my friends ran 255/50/18 tires on the front with no problem on his 04 sedan
Originally Posted by Braintree
I want to be sure I heard this right. Are you saying that 255/50/18's didn't rub at all and that they fit w/o any mods to the car? Was he running the same size on the back? I've been interested in 225/60/17's, thinking this would be the max size I could get (going for hieght and not width) for the front.
He had a mild drop.
Here it is (InTgr8rs past ride)
Maciejk, I dont know what year your car is. However I have an 06 Sedan which runs stock 234/45 18's. My car will have the same clearance as yours (assuming its an 03-06 which is the forum you posted in) unless you have changed your brake package.
There isn't much difference in size between 235/50 17 and 235/45 18's...
Stock Tire - 235/45R18
Section Width: 9.25 in 235 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 7.5 - 9 in
Overall Diameter: 26.32 in 668.52 mm
Sidewall Height: 4.16 in 105.66 mm
Radius: 13.16 in 334.26 mm
Circumference: 82.68 in 2100.0 mm
Revs per Mile: 790.2
Question Tire - 235/50R17
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 6.5 - 8.5 in
Overall Diameter: 26.25 in 666.75 mm
Sidewall Height: 4.62 in 117.34 mm
Radius: 13.12 in 333.24 mm
Circumference: 82.46 in 2094.4 mm
Revs per Mile: 792.3
So the long and the short of the situation is it just isn't going to rub... and I would consider finding a new tire guy!
S.DUNN
thanks for the input guys, i did end up with 4 michelin pilot sport a/s tires 235/50/17 they seem to be fine no rubbing, i just wished they looked better from the side
