Question: Extended studs w/ spacers
I have a question..i have a 04 coupe w/ Brembos
My front rims don't clear the Brembos 19x9 +20 offset
if i got extended studs w/ 15mm spacers do you guys think i would need to roll my fenders? Or would it just stick out too much?
Thank you so much!..
The fronts are already rolled from the factory, and I don't think you would have a problem fitting. Personally, you should just stick with a 10mm spacer but 15 will probably be ok.
I have Work Euroline KH 19x9 +20 in front
We tried the 10mm spacers and they barely clear (still touches the brembos), so my friend told me I might need 12, and I have to get extended studs because the lugs won't go on right..
Ill post pics when I have it on
seagrasser
May 3, 2022 09:43 AM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
