Ebay auction ends in a little, need urgent advice
Old May 29, 2004 | 12:31 AM
Hooby's Avatar
Will +30 offset fit on a sedan? 20 X 8.5 with 245/35/20
Really would apreciate it.
Old May 29, 2004 | 07:24 AM
khsonic03's Avatar
Re: Ebay auction ends in a little, need urgent advice
I would think not. I have a 32 in the front with 8", but it is very close. In the rear, there is less room unless you roll the fenders. I would go with a 38. That seems to be a good offset for most people.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, 19" Gram Light 57F Pro's, Hotchkis sways, Borla
Old May 29, 2004 | 01:01 PM
Hooby's Avatar
damnit, can anyone else confirm/deny this?
Auction ends in 5hrs....
Old May 29, 2004 | 03:37 PM
Hooby's Avatar
anyone, anyone at all? 2 hours left........
Old May 29, 2004 | 04:21 PM
RaySur350GT's Avatar
Looking at the charts and the stock offset for the sedan, you can use the rims. But a word of warning, you more likely will need to roll the fenders on the rear to make sure that you do not rub.
I have seen 2 G35 Sedans with the G35 Coupe 18" rims. The Stock 18s for the coupe is +30 offset, it pretty much flushes with the fender when using 225/45/18.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old May 29, 2004 | 04:23 PM
Hooby's Avatar
Thanks. If I rolled both front and rear it would give me even more room correct?
What is involved in rolling the fenders?
Old May 29, 2004 | 05:08 PM
Rolling the fenders is taking the inner lip of the fender wall and having the "rolled" up. Just take you hand and feel the rear fender edge, there is a lip. Basically it will be rolled up so that it will not hit the rim/tire when you hit any bumps or whatnot.
Also, you can only roll the rear fenders on this car. Hope this helps.
Old May 29, 2004 | 05:11 PM
Hooby's Avatar
So you're sure +30 will do ok?
Old May 30, 2004 | 10:50 PM
Hooby's Avatar
anyone? come on.... I've only gotten two opinions, one for one against.
Old May 31, 2004 | 05:56 PM
khsonic03's Avatar
I know this probably doesn't help, because it is a late post, but check out this chart. They won't fit. You would have to do narrow tires, and even then you can't be sure. I wouldn't risk it that close, because it will be a huge PITA to fix the problem. The most aggressive offset I would do in an 8.5" rim would be maybe a 33 or 34 with a narrow tire and you would HAVE to roll the rear fenders. Otherwise your wheels are going to stick out like a sore thumb and possibly rub during cornering.
https://g35driver.com/forums/showfla...sed&sb=5&part=
Old May 31, 2004 | 06:06 PM
Hooby's Avatar
yea, i couldn't retract my bid but i decided they wont fit.
Will 35 offset fit? Or should i just go 40/45?
Old May 31, 2004 | 08:17 PM
khsonic03's Avatar
I know 38 works. Many have done it, usually without rolling fenders. 35 is pushing it, but I have heard of giovanni doing it without rolling. If rolling fenders isn't a big deal to you, and you are planning on doing it anyway, then 35 will probably work with a 245 tire.
Freeman186
Sep 6, 2023 10:07 AM
Jussumman
Dec 22, 2015 10:23 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
