might get 19s (sedan)
Old May 30, 2004 | 08:04 AM
blackonblackG's Avatar
would this setup work -
19 by 8.5 axis milano with 40mm offset all around
goodyear eagle f1gs-d3 255/35 19 all around
thanks
Old May 30, 2004 | 10:12 AM
zimbo's Avatar
Re: might get 19s (sedan)
I'm inclined to think that it would fit.
--Steve
Old May 30, 2004 | 12:04 PM
im going back and forth with 18s and 19s. i have a question on the enkei RPM2. what bolt patern do i need and what are the pros and cons of a 35mm offset vs 45mm on an 18 by 8" wheel.
thanks.
Old Jun 1, 2004 | 11:37 AM
jran76's Avatar
The 18x8.5 with a 40mm offset would work very well on the Sedan. The RPM2's, which I just bought will work in either offset you mentioned. The +35 will stick out 10mm further than the +45. This will give a more aggresive look and also more room for big brake clearance.
Enkei has said the 18x8 with the +35 may not fit, I just don't see how it would not, but I will post in the next few days when I get them on. I had to go with the +35 to clear the Stoptech big brake kit.
It has also been posted that if you call enkei, they can give you more information, they have test fitted the sedan before.
2004 6MT Sedan-- Diamond Graphite
Stoptech 13" Brake kit-- Nismo S-tune Suspension
2003 Nissan 350Z--SOLD
Old Jun 1, 2004 | 12:17 PM
khsonic03's Avatar
I have 19x8's with a 32 in the front that fit beautifully. In the rear, you would probably have to roll the fenders. Alot depends on tire width as well. I have 225's on the front, and I think I could probably squeeze 245's on there, but I am not positive.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, 19" Gram Light 57F Pro's, Hotchkis sways, Borla
Jusseth
Sep 13, 2020 12:25 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
TheKnite
Aug 14, 2015 07:59 PM
chinee
Aug 8, 2015 10:11 AM
teamghost
Jul 28, 2015 04:52 PM
