will these rim/tire size fit 2003 g35 coupe with m6 (brembo brakes)?
Old Dec 8, 2008 | 07:46 PM
G35-M6's Avatar
will these rim size + tire size fit a 03 g35 coupe with m6 (brembo brakes)?
Fronts:
18x8.5
35 mm offset
235/40/18
Rears:
18x9.5
35 mm offset
265/35/18
if it doesn't, will a spacer make it work? and what size spacer should i get?
Old Dec 8, 2008 | 07:50 PM
nghiars's Avatar
rim size/offset should fit face but whether determine whether or not they will clear brembos. Offset is a bit weak so I would put spacers on for looks which may be required to clear brembos.
Old Dec 8, 2008 | 08:49 PM
CreativeDesignZ's Avatar
you will need a spacer to run those if you have brembos i think a 30 offset is the offset of oem 18's
Old Dec 8, 2008 | 10:28 PM
G35-M6's Avatar
are there different sizes for spacers?
Old Dec 8, 2008 | 11:23 PM
EL-EE-ES's Avatar
spacers mostly come in 3mm, 5mm, 10mm, 15mm, 20mm, 25mm
Old Dec 9, 2008 | 12:58 AM
G35-M6's Avatar
and how do i know what size i need to clear the brembo and make the offset work?
so since the rims is +35 and stock oem is +30 to clear brembos, does tha tmeans i neeed 5 or 10mm spacer?
Old Dec 9, 2008 | 08:53 AM
well the thing is, im not sure is 30mm is the closest you can get away with, either way your going to want at least a 25mm spacer for them to look decent on your car
Old Dec 9, 2008 | 11:56 AM
EL-EE-ES's Avatar
what type of rims are they? you need to see if the spokes will clear
Old Dec 9, 2008 | 04:32 PM
G35-M6's Avatar
these are the rims i'm looking at
https://g35driver.com/forums/18-inch...res-900-a.html
Old Dec 9, 2008 | 04:38 PM
dont buy that crap, those wheels suck
Old Dec 10, 2008 | 07:05 PM
G35-M6's Avatar
what are some decent brand that won't break my wallet?
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
KruZZe
Feb 27, 2023 05:04 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
