wheel fitment help
Old Dec 21, 2008 | 04:14 PM
zhuangzi's Avatar
damn you are on point!
car is stock, still has dealer plates from when i bought it used a few months ago.
i plan on getting coilovers later. i'm not a fan of dumping it to the ground, but i am also not afraid to roll the fronts either
Old Dec 21, 2008 | 04:15 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
no drop at all yet? hmmm... The fronts will stick out if you put a 275 tire on em. The rears should be fine but you might need a little added camber.
I'd do a 245/45 up front and a 275/40 in the rear.
-GP-
Old Dec 21, 2008 | 04:20 PM
zhuangzi's Avatar
-GP-
i'm going to put coilvers on before i mount the wheels on, and when i lower i am thinking maybe a 1-2 finger gap in between the fenders front and rear, but since this is my 1st experience with this car i'll have to see how it looks first before i know for sure)
i also want to run equal sizes on all 4 corners so i can rotate every time i change the oil.
i've got bout 1.5 months til i order tires and stuff, so i'll keep searching for info.
thanks for the help Gdup35sedan
Old Dec 21, 2008 | 07:54 PM
Matthew121's Avatar
just run 255 45 all around
Old Dec 21, 2008 | 07:56 PM
that would be a waste of the rear when you can easily fit a 285. At the very least, i'd run a 265-40 tire all around
-GP-
gotcha, well if you do a 1 finger gap, you should be fine with a 275-40 all around.
-GP-
Old Dec 21, 2008 | 08:20 PM
zhuangzi's Avatar
thanks again guys, i appreciate the help!
Old Dec 21, 2008 | 11:45 PM
Matthew121's Avatar
-GP-
true, can you fit that with out coilovers though?
Old Dec 21, 2008 | 11:56 PM
he said he was going to be running coilovers before mounting the wheels, otherwise, no, they wouldnt fit with the car at stock ride height.
-GP-
Old Dec 22, 2008 | 08:47 AM
Matthew121's Avatar
oh i see.
Old Dec 23, 2008 | 01:22 AM
Sylvan lake V35's Avatar
I wonder how many guys that extra bolt on the front has caused grief for?
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
joedaddy1
Jul 28, 2015 02:58 PM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
