9.5 Rears vs. 10.5 rears
Old Dec 22, 2008 | 04:18 PM
daniel3ooo's Avatar
I'm currently considering purchasing some SF Challenges but the wheels are 19x8.5 and 19x9.5 and I believe the offsets are +21 and +23
Do you guys think this is aggressive enough?
I use to have the exact same wheels on my 04 G Coupe but at times felt it wasn't aggressive enough and at other times thought they were perfectly fine...
What do you guys think? Is 9.5 rear large enough or is the one inch difference noticeably different?
Old Dec 22, 2008 | 04:22 PM
alphamatt's Avatar
9.5 on a rear is no bueno
Old Dec 22, 2008 | 05:28 PM
str8dum1's Avatar
throw in a 20mm spacer and it will be spot on.
Old Dec 23, 2008 | 03:59 PM
G35sedan03's Avatar
if you can, you def want 10.5 in the rear of a coupe
Old Dec 23, 2008 | 04:24 PM
delion21's Avatar
10.5 in the rear...no spacer needed
Old Dec 23, 2008 | 05:25 PM
shabarivas's Avatar
10.5 or go home... 9.5 w/ spacers will look good but its the offset that will make your wheels look not soo agressive... but if you dont care about the looks... (which i assume you do...) shouldnt matter
Old Dec 25, 2008 | 11:01 PM
Skaterbasist's Avatar
Retired SuperMod
Anything smaller than 10's in the rears is a waste of money (imo).
10.5 would be the best choice.
Old Dec 25, 2008 | 11:20 PM
Triple8Sol's Avatar
You'd want 10.5 in the rear, but if you must keep your wheels, then this guy is right.
Old Dec 25, 2008 | 11:27 PM
daniel3ooo's Avatar
Thanks for the response guys...instead of "settling" this time around I will wait for some 9.5f and 10.5r SF Challenges
Old Dec 27, 2008 | 01:56 PM
G35sedan03's Avatar
good choice my man on waiting, you will not regret it once you see those puppies on.
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
G4ORCE
Aug 22, 2015 01:16 PM
linedr89
Aug 17, 2015 05:11 PM
