G37 19's on 2006 G35X sedan
Old Dec 28, 2008 | 08:35 PM
jbot's Avatar
I have a set of 19" G37 Wheels that I am looking to put on my 2006 G35X. Will the staggered wheels do damage to the drive train? I was looking to run 225-40-19's all around.
Old Dec 28, 2008 | 11:32 PM
jedmonds's Avatar
As long as you are running the same width tires on all 4 wheels, you should be fine. I would probably go 235's or 245's all around though.
Old Dec 28, 2008 | 11:39 PM
GT-ER's Avatar
Width shouldn't matter...tire diameter is what matters. As long as all the tires are the same size in height, the car can't tell the difference if it's staggered or not.
For example:
a 225/40/19 tire measures 82" total diameter.
a 255/35/19 tire also measures 82" total diameter.
Old Dec 28, 2008 | 11:44 PM
jedmonds's Avatar
For example:
Good point, but not all tire companies have the exact same measurements for total diameter on their tires.
If you are going to run staggered tire sizes, check the manufacturers website to make sure the total diameter does in fact match front and rear.
Old Dec 29, 2008 | 12:13 AM
GT-ER's Avatar
Correct...but as long as all 4 tires are from the same company then it won't matter.
Old Dec 29, 2008 | 12:31 AM
jedmonds's Avatar
Not necessarily. Even tires from the same manufacturer will be off. within their sizes...
225/40/19 for nitto invo's have an inflated diameter of 26.18 inches 793 revs a mile
255/35/19 for nitto invo's have an inflated diameter of 26.10 inches 796 revs a mile.
I know its only .08 off, so it probably won't make much of a difference, but its not an exact match either...
Old Dec 29, 2008 | 12:33 AM
GT-ER's Avatar
Even the same exact tires can be off by .08... the car allows for some tolerance for tire wear.
BTW- I said diameter above and meant circumference...though it doesn't make a difference...the point is still the same.
Old Jan 8, 2009 | 09:35 PM
jbot's Avatar
Thanks for the info guys. Much appreciated!
Cajuncowboy
Jun 21, 2021 09:47 AM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
Mac8008
Aug 4, 2015 09:19 PM
atk08
Jul 30, 2015 03:12 PM
