What tire size to use?
Old Jan 6, 2009 | 01:18 PM
Mad A's Avatar
My car is an 04 coupe with Brembo's and OEM 18's. I just bought Enkei RPF1 rims, 18x9.5 front and 18x10.5 rear, both are +15 offset.
What is the correct tire size to use to avoid messing up the speedometer readings?
I am trying to figure it out using http://www.miata.net/garage/tirecalc.html can anyone provide the OEM tire dimensions? The stickies all talk about the wheel dimensions. Or if you flat out know what size tires I should use on the Enkei rims that works too!
Old Jan 6, 2009 | 01:25 PM
redlude97's Avatar
255/40/18 and 285/40/18
Old Jan 6, 2009 | 01:29 PM
(ar|'s Avatar
you could use: front 255/40R18 and rear 275/40R18 wich are the realy close to the stock dimension less than 0.2% diference
Old Jan 6, 2009 | 02:13 PM
Mad A's Avatar
Thanks for the help guys!
Old Feb 10, 2010 | 12:36 AM
syshs's Avatar
Is it ok if I went with thinner tires on these wheels with those specs?
Like, 255/35/18 and 285/35/18 or even
Like, 255/35/18 and 285/30/18 ?
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
