aggressive fitment - how do I make this work? (pics)
Old Jan 18, 2009 | 12:53 PM
V35 Skyline GT's Avatar
6MT Coupe
Watch it on more neg camber.
You'll still rub bad when digging in a turn while loosing the negative on that side in a turn.
Been there done that bro...
But give it a shot first I guess.
G/L and give us an update.
Old Jan 19, 2009 | 08:28 PM
patman530's Avatar
Update: raised ride height all around, dialed in additional negative camber. no more rubbing, but no more slammed
Old Jan 19, 2009 | 08:29 PM
Ghayes23's Avatar
Looks good Pat. I'm surprised you can't go lower though.
Old Jan 19, 2009 | 08:32 PM
patman530's Avatar
^^ yeah, the rear is about as low as it can go. I may lower the fronts a little more
The rear rubs whenever the road is bumpy.
Old Jan 19, 2009 | 08:35 PM
Ghayes23's Avatar
Your rear is about the same height as mine, and mine rubs occasionally with my 285's
Old Jan 19, 2009 | 09:34 PM
redlude97's Avatar
looks great to me, can you roll the fenders any more?
Old Jan 19, 2009 | 09:38 PM
patman530's Avatar
possibly on the rear, I'm a little hesitant to roll the rear more myself. a local tuner shop rolled it for me. I rolled the fronts more so than the factory roll, and while it served its purpose, I think I went a little overboard and flared it out too much.
Old Jan 19, 2009 | 09:45 PM
GreenGoblin's Avatar
The goblin resurrection
If its not flat it can be rolled more
Old Jan 19, 2009 | 10:33 PM
BolivianFuego's Avatar
Have you tried just driving it lowered and overtime the tire to fender will rub itself out?
I did this along time ago with a car of mine back in the day with agressive offset.
Old Jan 19, 2009 | 11:31 PM
partyman66's Avatar
Your car looks real nice with those rims and tires as you have it setup now.
Old Jan 19, 2009 | 11:46 PM
ShanesG's Avatar
It looks like it'd barely rub, just roll the fender a lil more of adjust the camber slightly!
Old Jan 19, 2009 | 11:48 PM
patman530's Avatar
I may be running stretched tires for my next set of tires so that I can get more clearance and slam it again
Old Jan 20, 2009 | 01:05 AM
str8dum1's Avatar
u can can go way more on the camber. more camber, flatter roll and put the drop back where its supposed to be
Old Jan 20, 2009 | 01:11 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
put the front back down, it doesnt look right that high. The rear height is fine for now. an additional half degree of camber would help stop the rubbing, and like others said, flatten the fenders if they're not already.
If you're going to stretch the tires on your next set, run a 265/35, you'll gain an extra 5mm of clearance from the tire to fender if you go with the same brand/model tire.
-GP-
Old Feb 5, 2010 | 04:38 AM
  #30
steeb's Avatar
a 245/40 would be perfect for 10.5. if u dont want to run so much camber, 245/40 may also let u dial out some neg camber.
