aggressive fitment - how do I make this work? (pics)
Old Feb 6, 2010 | 02:10 AM
  #31
elperuano's Avatar
Car is sick bro. Stretch tires more n lil more negative camber. 275 is hella lotta meat. Im at +0 on a 255 no rubbin whatsoever n slammed. Good alignment shop would help too. Sick set-up me likey!
Old Feb 6, 2010 | 02:15 AM
  #32
xXHotelCrazyXx's Avatar
What are the specs on the front wheels pat? just curious as to what offsets, wheel width, and spacers those are as well.
Old Feb 6, 2010 | 09:51 AM
  #33
patman530's Avatar
I've been running 255/35s in the rear for a while now, there is no more rubbing but I'm going to go more aggressive soon with -1 offset. Still should fit fine though as there is some room back there now.
Hotel, I'm running 235/35s now in front on 9.5x19 +28 w/25mm spacer. This thread is old, back when I had 255/35s.
Old Feb 6, 2010 | 11:59 AM
  #34
I was curious because my works that im going to be putting on are a +9 all around with the same wheel widths and a 245/19/35f and 275/35/19r
Old Feb 6, 2010 | 12:49 PM
  #35
elperuano's Avatar
lol no need to delete ur post jayk... geez never saw the date.. brought this thread back from da dead!
Old Feb 6, 2010 | 01:04 PM
  #36
patman530's Avatar
rears may or may not rub depending on how much neg camber you are running.
fronts should be good
Old Feb 6, 2010 | 03:21 PM
  #37
Im not sure, right now i havent played with the camber but it will be dropped pretty low with my new coilovers
Old Feb 6, 2010 | 05:14 PM
  #38
So pat, you think my +9 offset will be pretty aggresive????
Old Feb 6, 2010 | 06:50 PM
  #39
patman530's Avatar
^^ a while ago that would be pretty aggressive. these days, that's just mildly aggressive. but I think +9 all around would give you a pretty decent stance
Old Feb 6, 2010 | 07:03 PM
  #40
Yea...what are your offsets again with spacers?
Old Feb 6, 2010 | 07:07 PM
  #41
patman530's Avatar
F: +3 9.5
R: +4 10.5 (will be -1 soon)
Old Feb 6, 2010 | 07:17 PM
  #42
Ghayes23's Avatar
I'm going to try to run 15mm spacers on my wheels for now. I wonder how that will work. it would be 9.5+2 and 10.5+3
Old Feb 6, 2010 | 07:18 PM
  #43
Ghayes23's Avatar
F: +3 9.5
Do you have a 25mm spacer I can get from you for my gt-7's?
Old Feb 6, 2010 | 07:21 PM
  #44
I do if you have a 30mm for me
Old Feb 6, 2010 | 07:44 PM
  #45
patman530's Avatar
Eldin has dibs on the 25mm..
Are you going to run stretched tires with the 15mm spacers?
