my gts doesnt clear my bbk.. need help..
Old Jan 30, 2009 | 02:18 AM
cchaorule's Avatar
so before i ordered my volks.. i asked around and everyone including the vendor told me 19x9.5 +17 and 19x10.5 +18 will clear BBKs.. but today after getting tires mounted on.. i realized that the rear did not clear my ap racing brakes.. i will need spacers.. what kind do i get?? i was able to get the wheel on and everything but the wheel just barely touches my brakes therefore making it unable to spin.. if i get spacers wouldnt the things that stick out not be long enough for me to securely lock my lug nuts?? i have no experience with this.. any help is great! thanks.. what spacers should i get?? thanks
Old Jan 30, 2009 | 02:21 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by cchaorule
so before i ordered my volks.. i asked around and everyone including the vendor told me 19x9.5 +18 and 19x10.5 +17 will clear BBKs.. but today after getting tires mounted on.. i realized that the rear did not clear my ap racing brakes.. i will need spacers.. what kind do i get?? i was able to get the wheel on and everything but the wheel just barely touches my brakes therefore making it unable to spin.. if i get spacers wouldnt the things that stick out not be long enough for me to securely lock my lug nuts?? i have no experience with this.. any help is great! thanks.. what spacers should i get?? thanks
if it barely touches, you can get a 3 or 5 mm spacer and clear the brakes. With a 3mm spacer you will have PLENTY of threads left on the studs for the lugs to grab safely. Some people recommend extended studs with 5mm spacers, but you can run them without. Get extended studs if want to be 110% sure about safety.
-GP-
Old Jan 30, 2009 | 02:49 AM
cchaorule's Avatar
thanks.. i heard wit the 5mm spacer you can only get 3 full turns in or something.. so that should be fine??
Old Jan 30, 2009 | 02:51 AM
redlude97's Avatar
FWIW, one of the local members snapped a few studs while running 5mm spacers without extended studs, i believe while running GT-S's, so you might want to keep that in mind. use washers to see if 3mm is enough clearance
Old Jan 30, 2009 | 02:53 AM
Kris79's Avatar
battle froggy
17mm rear u will need 3mm to clear
Old Jan 30, 2009 | 04:04 AM
cchaorule's Avatar
where can iget 3mm spacers?? is runing 15mm rear and 10mm with extended studs a waste of money?? and is that gonna make it too agressive with mysetup??
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
